2012/07/15
For your Information a New Version is out there:
Please Download Main Rom here:
Kernel for 7bG3:
Rainer
hpx70 said
Thank you for this ROM.but when I connect my device to PC neither MTP nor mass storage works, is there any work around?
How can I re-flash the original ARNOVA ROM?
You can get the stock firmware for the 7b G3 here:Â http://www.arctablet.com/blog/featured/arnova-firmwares-updates/
or try our custom firmware is more similar to the default firmware:
http://www.arctablet.com/blog/firmware/arnova-7b-g3-ics-custom-firmware-google-play-root/
In both case, use Rockchip Batch tool to flash.
hpx70 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2012/10/01
Forgive my ignorance, but I noticed the rom for 7bg3 also includes a link to a kernel for the 7bg3. Â I have the 7fg3 and would like to use this rom, do I need to also include the kernel? Â I guess what I'm really asking is are the 7bg3 and the 7f g3 simular with the exception of the amount of flash rom?Â
2012/11/15
Just found a battery fix that works for me.
http://www.arctablet.com/users/forum/battery_fix_update_beta.zip
It wouldn't install in CWM, so I did it manually.
Extract it on your computer and copy the services.jar in the system/framework directory to your SD-card.
Insert the card into the tablet and start it.
I used ES File Explorer to do this.
Give it root rights.
Then copy services.jar to /system/framework, press OK if asking to merge.
Reboot to recovery with Reboot app.
In CWM, go to Advanced.
Wipe battery stats, then press Fix Permissions.
If all goes well, battery meter works fine. (at least for me)
The following users say thank you to gamefreak61 for this useful post:
virtualkannan007, hpx70
2012/08/25
gamefreak61 said
Just found a battery fix that works for me.http://www.arctablet.com/users/forum/battery_fix_update_beta.zip
Awesome... Worked As a charm for me tooo..... Keep up the good work... Â Thanks a lot
92 Guest(s)
Devices in use: Desktop (81), Phone (11)
jackthomas
hakhiem
jenom
kfwacky
fer30
culo1
