Topic RSS Related Topics
NEOCM10 "LEON" Jelly Bean Rom *Testing*
Topic Rating: 0Topic Rating: 0Topic Rating: 0Topic Rating: 0Topic Rating: 0 Topic Rating: 0 (0 votes)
2012/09/28
21:54
Forum Posts: 26
Thanks Received: 14
Here ist for Testing my new Rom. It´s called NEOCM10 "LEON".
The Rom has CWM Recovery.
Please Test it and give me Feedback.
Feature:
Apex Launcher
Google+
Google Talk
YouTube
Google Mail
Google Now
Working:
Seems all is Working, Feedback Please.
Not Working:
You Tell Me
Installation:
1.: Download the ROM here
1a: Kernel for 7b G3 here
No Mirrors Please !!
2.: Unpack it
3.: Change to RKAndroid_v1.29
4.: Run "RKAndroidTool" as Admin
5.: Check Loader and Press EraseIDB
6.: Uncheck Loader and Press Run (For 7b G3 change the Kernel to the Kernel Image for the 7b G3)
7.: When Finishd the ROM will Restart in the CWM Recovery
8.: Reboot Now
9.: Starting Up wait 5 Min and Reboot Again
10.: Have Fun
The following users say thank you to neomode for this useful post:
admin, kubilay2000, igotdez, virtualkannan007, ab3, CroCop, h.a.m.i.d, spookykoman
2012/10/04
15:03
The motion sensor does not work properly and everything else is going great.Laugh
03:14
Arnova 7 G3
any help im getting an error telling me "no rkAndroid rock usb found'
Nvm i got it to work i just had to have the tablet turned off first and then it on reset mode after installing the drivers…
The following users say thank you to igotdez for this useful post:
exelletor
04:46
Arnova 7 G3
the rotation sensor seem to switch to opposite sides depending on how u hold the device hopes this gets a quick fix other then that it seems fine.
2012/10/08
04:02
Arnova 7b G3
Will Netflix work with this ROM?  Mine will load it with the OE or the ARCTools custom ICS ROMs, but will not play anything on Netflix.
2012/10/08
09:23
Forum Posts: 3685
Thanks Received: 1012
JMI Pulse 10
Living outside the US, I cannot use Netflix Confused So I can't say, you'll have to test by yourself and let us know.
The new firmware should be out by tomorrow.
2012/10/09
03:56
Arnova 7b G3
Ok.  I followed the instructions, but the tablet does not reboot into CWM.  Am I missing something?  What is supposed to be in the Offset field for the kernel?
2012/10/22
04:23
Arnova 7b G3
Working Fine… ;-)
The Pros Are Numerous like , Screen Shot, Increased App Storage Space,etc
But there are some problems
1.No Volume Control Buttons.
2.Charging Indicator And Battery Level Is not proper
3.Orientation Problem In Face Lock.
Hope You will Fix these soon.
Anyway Thanks a lot for the Jelly Bean. Great Job.
CoolCool
2012/11/06
19:59
Arnova 7f G3
Will this work with the 7F G3 as well?   I know this is all volunteer and if I had the knowledge I would help but I don't.
2012/11/06
20:27
Forum Posts: 26
Thanks Received: 14
Yes i think so, the main Diffrence is it has 8 GB Internal Memory.
By the Way there is a new Version out there.
You can find it here.
d-h.st/users/neomode
Kind Regards
Rainer
crashogre
2012/11/15
20:06
Arnova 7b G3
@Neomode
Any chance of getting the battery indicator working properly?
It starts at 85 % and stays there.
2012/11/15
21:12
Forum Posts: 26
Thanks Received: 14
There is a New Version out there, you can it found here:
Rom:
Kernel:
Battery Fix:
Regards
Rainer
2012/11/17
16:01
Arnova 7b G3
@neomode
After update with battery fix, the tablet went in continues bootloop. I noticed it was an update for the 10G3?
Flashed it back to stock. updated it again, and the same thing happens. The update will not install with CWM,
so you have to place in the corrct drawer. After doing this, the first reboot goes well, battery indicator shows the
right numbers. At the next reboot, it wil not go past the bootanimation. So I'm back to stock again.
Regards
Jurrit
2012/11/20
04:57
Arnova 7b G3
OK, I followed the instructions, and after it says complete, the tablet doesn't reboot.  Am I missing something?
DERP!  I figured it out.  I forgot to unpack the kernel.img!  Yell
2012/11/20
14:39
Arnova 7b G3
Netflix works!  Only issue I have is the new Angry Birds Star Wars won't run…
Most Users Ever Online: 646
Currently Online: cucurucu, dotnetfan, xman88, lere01, TabletUser, billkaroly, mdv, taoabao11, md990, saltamon, bs160305, makwu, viniciuselario, CRH, nguyen0024, emanuele
126 Guest(s)
admin: 3685
globula_neagra: 1876
Guest Posters: 36
Members: 74558
Forums: 122
Topics: 2807
Moderators: HaroldG (117), globula_neagra (1876), exelletor (344)
Administrators: admin (3685)
