2012/12/08
OK hi guys, I used DPI modder to increase the dpi *slightly* on my device but it kept crashing the launcher, luckily I had apex installed which fixed that. i recently did a factory reset, forgetting that I altered the dpi and now the launcher crashes and I have no way to install/launch dpi modder to correct my mistake.
I tried installing remotely from my pc using the play store but the download is never sent to the tablet even though play store says "will download shortly" obviously I cant launch any apps or anything. please is there any way to reset the density?
HEEEELP thank you in advance. also please be kind i know it was stupid lol.
reflash the tablet if you did not enable the usb debugging, if you have usb debugging activated use QtADB and copy the build.prop to your pc, edit the build.prop, mount the system via adb, then copy the edited build.prop back to your tablet., reset, and you should be fine
2012/12/08
I cant do either, QtADB wont detect it cos when i plug it into my laptop it says "device driver was not successfully installed" and going into recovery i get andy laid on his back with a red exclamtion point but no drivers are installed on my laptop why did I buy an arnova? *stressed now*
96 Guest(s)
Devices in use: Desktop (86), Phone (10)
Ellocojoe
Tonysc17
olegator
Ur
beelink
TheMentor
