How can I enter APN?
ludibubi
Forum Posts: 15
2012/10/15 - 00:18
So, I bought an USB-OTG-Cabel and connected an Huawei E220 UMTs Modem. After a few seconds appears s screen, where I have to enter the PIN. After this I find in the right corner an icon for the signalpower (with 3 of 4 segments). But in the settings I read "No internetconnection)
Now I looked in Settings/More/Mobile. In APN there is nothing listed. In the upper right corner I find a button where I can enter a new APN. I have Eplus and I entered the datas, which I found in the internet. But when I have entered everything there is no button to save this! What must I do to save this? I think that the modem than works....
Regards Ludger
Thanks Received: 3177
2012/10/15 - 00:24
From what I remember (I don't have a tablet here to check), the option to save the APN is offered when you have entered all the APN details. You should see it at the bottom of the screen after pressing the Option menu in the top right corner.
ludibubi
Forum Posts: 15
2012/10/15 - 23:43
No, there is not such an option. When I tap on the button in the upper rigth corner and choose "New APN" appears a layer in which I can enter the details. I call it layer because it is no window or sth like this. The original desktop get's darker and the page, where I can enter the details is highlighted. But there are no buttons to close or save, also not when I have entered all nessesary details. And when I tap on the upper right corner after entering details then this "window" disappear and nothing mor happens The screen looks like before I started the process.
Regards Ludger
ludibubi
Forum Posts: 15
2012/10/16 - 21:21
Now I used the option "Reset all APN-Settings to Standard". After a while all APN and all MobileProviders are deleted. I started the tablet new and connected the modem. After entering the PIN the modem flashes and suddenly I was connected to the internet. I don't know why, but it works!
Regards Ludger
2012/10/16 - 21:43
That's great, thanks for reporting back Wink
Currently Online: hamishduke
83 Guest(s)
Devices in use: Desktop (75), Phone (9)
hamishduke
squal
squalangel
anqilan456
havetoregister
werasler
