Battery easily drained
tenvs7th1
2012/07/13 - 09:29
I've recently bought a Arnova 7b G3 and after opening the box I immediately used and install the applications without even charging it first. Now the battery easily gets drained. Is there anyway to make battery last much longer?
Thanks Received: 3177
2012/07/13 - 09:34
I remember that on batteries from older technology such as Nickel Cadmium (Ni–Cd) it was recommended to make a full charge followed by a full discharge to improve the battery life. I don't think this is valid or necessary anymore on newer batteries like Lithium Ion ( Li-ion) batteries.
How much battery life are you getting ? On a continuous video play, with Wi-FI disabled and brightness at 50% we usually get between 4 to 6 hours depending on the tablet model.
tenvs7th1
2012/07/13 - 09:39
With continuous playing and downloading some apps, around 1 1/2 to 2 hrs. Just like today I charged the tablet for more than 12hrs and I've only used it around 20-25mins and its already showing 29% on the battery meter.
2012/07/13 - 09:45
This sounds like a defective battery.
We have no Arnova 7b G3 to test here, maybe other 7b G3 owners can share they view on the battery life ?
fr4nktm
Forum Posts: 14
2012/07/14 - 16:26
i have the 7B G3 for a while now and i have noticed this battery being drained quickly too for only about 2 hrs use.but i tried lowering the brightness and turning off the wifi and it last a little bit more. And its true charging it usually takes a while until fully charged.
tenvs7th1
2012/07/15 - 16:13
Does the battery meter of yours turns green when fully charged? Because for my arnova, even if I charge it for more than 12hrs the battery meter is still yellow.
fr4nktm
Forum Posts: 14
2012/07/15 - 17:05
the led on side does not turn green, but while charging it's red then upon fully charged it turns yellow orange. what battery meter  are you referring too?
tenvs7th1
2012/07/15 - 17:28
I see.. Because, on their manual it says here that it will turn to green when fully charge.
fr4nktm
Forum Posts: 14
2012/07/15 - 19:02
never get to see the manual lol.but the led never did get to green color
SupArnova
Lubbock, T.X.
Forum Posts: 33
2012/07/15 - 19:19
this is how my 8 g3 and my 7b g3 do with the orange light i ran both playing movies in loop and my 8 g3 died at 4.2 hours and the 7b g3 at 4.5 hours no wifi 50% brightness
Arnova 8 g3 - kasty-arn8g3-40-042:::
Arnova 7b g3 - kasty-arn7bg3-40-042 :::
ChildPad - kasty-arnchildpadr-40-04 ::: LG Optimus s - Reborn rom 2.2.4 :::
2012/07/15 - 23:51
Thanks for these tests and numbers Wink
Do you mind doing it again soon with my battery benchmark application ? (I'll give you all details on how to proceed)
SupArnova
Lubbock, T.X.
Forum Posts: 33
2012/07/16 - 02:30
no problem let me know how to use it or where to get it and ill be right on it
sepehr_3862
2012/10/05 - 06:25
I have this problem like you, i dont charge it for first ttime and use it, and now long time need for charging, and it drain fast , last night when device was standby and every things was off and auto task killer was on, in 6 hours it decrease from 57% to 33% .please help me. is this tablet normaly has week battery or my device is damaged ?:-( i bought it 6 days ago
tenvs7th1
2012/10/06 - 06:34
I think there's nothing we could do on this. For the Arnova tablet that I bought for my Mom, she told me that when she's using it, if its fully charge about 23mins or less the battery runs out. Big mistake for not charging 8hrs before using it....
2012/10/06 - 11:31
I'm not a specialist Wink but I don't think, that today's LI-Ion and Li-Po used on our devices have an important "memory" effect, so you shouldn't ruin it if you don't fully charge on first use just after unboxing...
If 23 mins is the full battery life, there's definitely a problem with the tablet.
Currently Online: ri9000
81 Guest(s)
Devices in use: Desktop (73), Phone (9)
hamishduke
squal
squalangel
anqilan456
havetoregister
werasler
