Problems with turn it on
Agueda
2012/04/04 - 16:32
Hello everyone, I first want to apologize for my English, I will try my best to express.
I have this tablet, the ARNOVA 7b g2. I worked perfectly but as I turn it on one day was nothing but black screen with white sign at ARNOVA. can not get on, not put it in recovery mode. What I can do? archos support technician tells me to just send it but I have no warranty. please help.
Thanks Received: 3169
2012/04/04 - 17:22
You can try to flash a firmware using Rockchip flashing tool:  http://www.arctablet.com/blog/featured/flashing-arnova-g2-rockchip-2918-rockchip-flashing-tool/
You'll need a firmware for your device, is it a capacitive or resistive (DT, Dual Touch) model ?
Agueda
2012/04/04 - 20:27
it´s de dual touch model
and i have a question, in my case how do I put the tablet in recovery mode? or it is not necessary
thank you very much
arnova 7b
2012/05/11 - 13:48
Try reset the tablet with a pin insert into the reset hole, it may solve your problem
If not work, the try the RK2918 recover
This can be done by :
1. download necessary software
2. Table enter recover mode-->pin the reset hole and at the same time press power-on button and insert USB to computer
3. Run the RK2918 firmware update program
Good luck
92 Guest(s)
Devices in use: Desktop (85), Phone (7)
atgyuric
BBonch
crispyduck00
asgard2701
Rob_nl
shadowlabs
Topics: 6028
Members: 261274
