Problems with this tablet
mickeybhoy6
2012/03/17 - 19:00
 Hi guys,
Recently purchased a Archos Arnova 7b G2 tabet. Got a great deal(£99) however I have now found out why.
Having a couple of problems with the firmware. Firstly flash does not seem to be working. When I try to open a website that uses flash it just crashes. Also I cant get into the settings for flash. I checked the comments in applib and other people seem to be having this problem with other arnova tabs. Does anyone know of a fix?
Also some other websites I use crash while using them. They just shut down and go back to the search screen. Also facebook, skype and youtube do not work. I tried updating the firmware but there is no updated firmware for this exact model. I tried the firmware for the other arnova 7's however it just asks if I want to delete the firmware.
Anyone else had these problems? Any easy fix?
I have contacted archos but no answer yet. I will return it to the shop though if I dont get it sorted soon,
Thanks,
Michael
Crundy
Forum Posts: 15
2012/03/21 - 17:05
I'm having the same Flash problem as you. I suspect it's something that Adobe has to fix and so your best bet is to leave a comment on the market for the flash player until they fix it. The only other option is to try and find an older version of the flash player. It seems it was broken in the last update.
To stop your tablet crashing in the meantime change the browser settings to run plugins on demand. OK you won't be able to view the flash content on the page but at least the browser won't keep crashing.
Spaceman
Forum Posts: 26
2012/04/04 - 23:43
mickeybhoy6 said
 Hi guys,
Thanks,
Michael
Hi Michael,
You have probably sorted the problem out but this is what happened to me. I have flash on the 7b G2 when I bought it, but when I went onto the Appslib site it said there was an update, so I installed it, BIG mistake, nothing them worked not Youtube, nothing, I uninstalled it, went to the Flash site and installed the one that came with the tablet, and now it's working fine 🙂
86 Guest(s)
Devices in use: Desktop (83), Phone (3)
dcatalan
dshepp
kaironit
qweku1
himeji
robotx
Topics: 6028
Members: 261291
