Lost password?
The forums are currently locked and only available for read only access
[ ROM ] Android Market and root on your Arnova 7b G2 DT (Dual Touch) with our EZ custom firmware (v1.1)
This topic is locked
gogoulis
2012/04/18 - 23:14
Hi, after i did the firmware update through the arctools and add the google apks everything working except the play store has very few apps.why this happening??
Thanks Received: 3177
2012/04/18 - 23:20
Have you tried the Market fix as explained in the blog article ?
gogoulis
2012/04/19 - 00:12
well i tried for third time i unistall all google apps and install again and worked!!
btw if i use mobo player can i watch 1080p movie?cause the main player cant play the video i and i cant put the video in the internal memory cause of low space
Thanks Received: 268
2012/04/19 - 00:24
why would you want to watch a HD movie on the tablet ?, get a dvd rip and you will not tell the difference, or at least a mobile edition encoded in 800 with 480 mp4 format.
nasha
2012/04/26 - 23:01
Hi. this worked for me, and I was very happy with it..but now my tablet wont charge anymore!! I still have warranty, but now I did this i guess i dont have warranty anymore.. how can i delete play store and stuff? How can i get back to the original settings??? Cuz i know i cant give this tablet to company to repair it with Play store etc on it?? ūüôĀ
2012/04/26 - 23:04
I'll check for a dump of the Arnova 7b G2 DT firmware, I made one a while ago.
nasha
2012/04/26 - 23:47
Oh thank you... !!! Im so desperate to get the original firmware back >_< so i can get it repaired.
mcnob
2012/06/18 - 20:44
Only recently got the 7B G2 (resistive) and I'm desperate to get the market (Play Store) up and running on it.  I've run through the ArcTools method and it installed fine.  I managed to get into the market and download a couple of apps but the next time I went in, it only showed some apps.  I tried the market fix but that didn't help.  I've tried installing the very latest version of the market but that now shows "Not compatible with your device" when I try to download some apps that were fine before updating.
Sometimes I lose most apps when I reboot device and sometimes I just get the not compatible message but whatever happens, it's very flaky and just doesn't work anymore.
Is there a more recent firmware that ArcTools can be updated to as it seems it's no longer compatible with the new Play Store?
Failing that, is there another way to root the device and install the new Play Store or just edit the device info to make it work somehow?
Seriously......HHEEEELLLPPPPP..........lol
2012/06/19 - 09:15
Some custom firmwares have issues with Google Play, such as the "not compatible with the device" error you are experiencing.
I'm currently have a look at the firmware to make an update that should work better, if all goes well, it should be ready by the end of the day.
2012/06/19 - 10:44
The custom firmware update 1.12 should fix the Google Play missing apps problems, please have a look and let us know.
Get the firmware here:
http://www.arctablet.com/blog/featured/market-root-arnova-7b-g2-dt-ez-custom-firmware-v1-1/
or thru Arctools / firmware.
mcnob
2012/06/19 - 12:58
Updated through ArcTools today and IT WORKS.  All is good in the world and admin is my new hero.
Thanks a lot and you have just proved that android community love is the best there is......lol
onlyblack
2012/11/04 - 14:55
Hi, I buyed an Arnova 7bG2 Dual Touch (Resistive Display) tablet with 1.0.4.GINGERBREAD.eng.root.20111213.124400 firmware version.
I'd like to keep a rescue copy of the firmware but I can't find it in the Arnova Official site firmware list; how can I get a copy without dumping it? And is there any update of it after 1.0.4.GINGERBREAD.eng.root.20111213.124400 version?
Thank you so much
t7t7t7
2012/11/07 - 20:28
Ce firmware peut-il être installé sur un arnova 7b G2 (écran capacitif) ?
merci de vos réponses
a+
hairygreenthing
2012/11/08 - 18:03
a+
for the capacitive 7b g2 you want this firmware http://www.arctablet.com/assets/firmware/Arnova7G2/kasty-ez_arn7bg2cap-23-112.zip
and you install it using the guide here http://www.arctablet.com/blog/featured/flashing-arnova-g2-rockchip-2918-rockchip-flashing-tool/
pour l'7b capacitif g2 vous voulez que ce firmware http://www.arctablet.com/assets/firmware/Arnova7G2/kasty-ez_arn7bg2cap-23-112.zip
et vous l'installer en utilisant le guide ici http://www.arctablet.com/blog/featured/flashing-arnova-g2-rockchip-2918-rockchip-flashing-tool/
onlyblack
2012/11/17 - 14:37
Thank you so much
No one can help me? I want to change the firmware in order to use google play, but i prefere to keep a copy of the original firmware to restore if something fails
thanks
194 Guest(s)
Devices in use: Desktop (93), Phone (101)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
