G-sensor problem with google play apps
djgl3nn
Forum Posts: 11
2012/03/26 - 21:38
Recently I got a free Arnova 7b G2 and started to do some research on it.
Very quickly i found arctools and I installed the firmware that was selected for me (7b G2 capacitive touch). No problems at all untill I started playing labyrinth lite which i downloaded from google play. The g-sensor doesn’t work properly, if i tilt horizontal, the game tilts vertical and vice versa.
if i download labyrinth with appslib, then everything is ok. But upgrading it with google play messes the g-sensor up.
Is it possible to fix this? I think it will be only a minor change in a config file or something, but it will mess up the appslib version probably ( which is ok for me, i’ll only download apps from google play then)
Thanks in advance.
Currently Online: kindr
96 Guest(s)
Devices in use: Desktop (83), Phone (11), Tablet (3)
kindr
TOFIK
brzeg
ruslanrech
SteveBP
errih21
Topics: 6010
Members: 260674
