Contacts and Calendar on Arnova 7b G2 DT
Related Tags
sg72250
2012/07/02 - 21:58
With this tutoriel http://www.arctablet.com/blog/forum/arnova-7b-g2/tutorial-installing-android-market-on-arnova-7b-g2/ i installed very simply Google Market and Gmail on my Arnova 7B G2 DT. Thank you very much Audrik!
Now I would like to run the Google calendar and contacts but I can't find them in the Market or in APK. I thought they would be included in Gmail or in Google Services Frameworks.
Help me please.
Thanks Received: 264
2012/07/02 - 23:24
search for gapps on google, and you will find a pack with the apps that you are looking
sg72250
2012/07/03 - 09:04
I searched gapps on Google but i can't find a good version for my tablet. It's an Android 3.2.1 and there is no packs for this version (http://wiki.rootzwiki.com/Google_Apps#20110120)
I tried the 2.3.2 version but it doesn't work : installation fails with the message "Application not installed"
Do you have a link for a 2.3.1 android version ? Is there an order to install Gapps ?
Thank.
sg72250
2012/07/03 - 09:43
I found a compatible package for my android 2.3.1 on this topic (http://forum.androidspin.com/showthread.php/5525-ROM-KingsROM-Gingerbread-v6-w-gapps-1-17-11).
I installed all apk successfully and rebooted my tablet but contacts and calendar GUI don't appear.
sg72250
2012/07/03 - 13:14
Thanks globula_neagra.
I downloaded this pack but i can't install apk "
Parse Error : There is a problem parsing the package"
sg72250
2012/07/03 - 20:04
I found a Calendar.apk and installed it successfully but when i start Google Calendar, the application stops without message.
Do you know if the 1.12 EZ firmware (arctools) includes Contacts and Calendar ? I didn't want flash my tablet but if it's the solution ...
Thanks.
2012/07/04 - 09:40
Thanks.
Calendar app is supported, Contact isn't.
sg72250
2012/07/04 - 12:00
Too bad, it's contacts that interests me most.
J give up.
Thank you for your responses.
sg72250
2012/07/08 - 19:04
LaughLaughLaughLaugh YESSSS !
Finally, i flashed my tablet with Firmware 1.12 EZ and installed ContactApps from Google Play and it works !
I can consult my Google's calendar and Office's calendar (Exchange) with Calendar app, view my Google's contacts with Contact app (form Google Play) and use them in GMail app.
It's OK for me. Thank you Globula_neagra and admin for your responses.
147 Guest(s)
Devices in use: Desktop (136), Phone (11)
spiik
nikitamaan
VMILCINOV
