Arnova 7BG2 Erreur Wi-Fi (WIFI ERROR)
mamed84
2012/05/29 - 10:38
Bonjour ,
J'ai un problème au niveaux d'activation du Wifi ,A chaque Fois que j'essaye d'activé le wifi il affiche erreur.
Que Faire pour corrigé le problème
merci
I have a problem with activation of Wifi, every time I try to activate the wifi it shows error.
What to do to correct the problem
thank you
alex
Forum Posts: 252
2012/05/29 - 11:42
moved to correct forum
what does the error message say?
Thanks Received: 264
2012/05/29 - 12:02
use adb logcat to get an exact description of the error.
mamed84
2012/05/29 - 23:27
Alex, when I want to activate the wifi ,error appears.
mamed84
2012/05/29 - 23:29
globula_neagra, how used  , adb logcat
2012/05/29 - 23:55
install android sdk
adb drivers
then from cmd use the command
adb logcat
in all the time you need the tablet connected to the pc and usb debugging enabled also from the tablet
try then to see what is the error when you enable the wifi
and copy paste it here
there is a tutorial here on the site on how to install android sdk/adb
also use google for more info.
mamed84
2012/05/30 - 01:32
/WindowOrientationListener(  200): deviation = 0.29332447
I/PackageManager(  200): enter performDexOpt
I/EventLogService(  328): Aggregate from 1338332499092 (log), 1338332499092 (dat
a)
I/WindowOrientationListener(  200): x = -2.7537074 y = 5.201447 z = -7.3432198 d
eviation = 0.3959732
I/WindowOrientationListener(  200): deviation = 0.3959732
D/WiFiHW18(  200): ERROR: init_module return ret=-1
D/WiFiHW18(  200): Unable to unload driver module "wlan": No such file or direct
ory
E/WifiService(  200): Failed to load Wi-Fi driver.
I/WindowOrientationListener(  200): x = -3.3656423 y = 5.0484633 z = -7.4962034
deviation = 0.16260529
I/WindowOrientationListener(  200): deviation = 0.16260529
2012/05/30 - 01:38
you need to reinstall your firmware/reset to factory settings, one of this 2 options.
you are missing the wifi driver
i dont know what is the procedure for this device, search on the forum
mamed84
2012/05/30 - 10:54
merci
96 Guest(s)
Devices in use: Desktop (87), Phone (9)
atgyuric
BBonch
crispyduck00
asgard2701
Rob_nl
shadowlabs
Topics: 6028
Members: 261274
