Help Please
jackrabitt08
Forum Posts: 12
2011/11/22 - 10:55
Hello i have my arnova 7 with cyanogenmod and i cant install chainfire says no space..
If any solution?
Other problem with cyanogenmod that i cant activate usb storage? :S i clic on status bar but not open..
But other think is that i want to restore the original system but i dont now how. i put de update.img original (archos web) and theres no do anything.. help please!!
Thx to all.
Thanks Received: 3170
2011/11/22 - 11:03
I haven't checked the Arnova 7 CM7 firmware that you are using on your device, so I don't know about Chainfire space issue.
The CM7 firmware port from last week had some issues with USB, on some firmwares is may be locked to USB host mode. You should probably wait for a new firmware release.
To restore your system you need to use Rockchip flashing tool:
http://www.arctablet.com/blog/archos-tablet/flashing-firmware-rockchip-cpu-based-devices-archos-ht-7-8-arnova-10/
With the firmware of your choice.
For information, the official Arnova firmware for the device is here:
/blog/featured/arnova-firmwares-updates/
81 Guest(s)
2 Guest(s)
Devices in use: Desktop (68), Phone (13)
karim78190
mario millan
estelavg
Skyzhay
HorstG
techboy
