Cyanogenmod 7 + Chainfire 3d
jackrabitt08
Forum Posts: 12
2011/11/17 - 09:37
i get cyanogenmod on my arnova 7 and i install de chainfire 3d apk. For the moment all ok.
Later go to chainfire 3d app and i select the option intsall CF3D driver.
The device reboots, and reboot the loadimage and don't start the system! :S
If any can help
Thnx
Thanks Received: 3169
2011/11/17 - 09:46
CM7 port probably has limited support for 3D and CF3D just crashs, there isn't much to do unless wait for a CM7 update that may work better on this matter. If your device is "bricked" and does not start anymore, please use Rockchip flashing tool:
http://www.arctablet.com/blog/archos-tablet/flashing-firmware-rockchip-cpu-based-devices-archos-ht-7-8-arnova-10/
To flash the default firmware for your device:
/blog/featured/arnova-firmwares-updates/
Anyway, the Arnova 7 has very limited 3D capabilities due to its lower end Rockchip RK2818 CPU. There is little to expect in term of 3D gaming... I am not sure if CF3D has a real use here.
jackrabitt08
Forum Posts: 12
2011/11/17 - 14:19
mm.. ok thx
good info 🙂
and one thing I think I remove all " /data " folder..
me wants to remve /data/data/* and I do data/* (becouse prevously i have been do cd data/, I amb from ubuntu)
and i think is becouse that don't start. Any opinion?  i am not very good at android but doing prevously say for you (/blog/archos-tablet/flashing-firmware-rockchip-cpu-based-devices-archos-ht-7-8-arnova-10/) i can solution?
:S
Thnx
88 Guest(s)
Devices in use: Desktop (77), Phone (10), Tablet (1)
dw90582
massacremx
barleybob67
Demian99
st14n_
KJC3101
