V6 supercharger script for the allwinner a10 tablets (ours)
a_elizondo
Forum Posts: 22
2012/07/10 - 01:13
Please back up your stuff before doing this but tried it on mine and works great
http://www.freaktab.com/showthread.php?724-NETFLIX-FIXED!!-Simplified-V6-Supercharger-for-Allwinner-A10-ICS-RECOMMENDED!
Since our tablets have 1gb ram, supercharge it to any of the two options under 768+
Thanks Received: 3169
2012/07/10 - 10:49
Here are the details, originally from here
V6_SUPERCHARGER FOR ALLWINNER A10 ICE-CREAM-SANDWICH TABLETS.
PLEASE READ THE GUIDE CAREFULLY BEFORE APPLYING THE SCRIPT.
Download Folder: Simplified V6_SuperCharger Script
FEATURES:
1. Smooth and Fast Re-Draw of UI and Internet Browser.
2. Complete Memory Management Script. Not a Junk Android Manager.
3. No need for Crappy Android Task Killers and Task Managers. Just V6_Supercharger Alone.
4. 100% Safe. Unless you want to explore the other options of the Script.
REQUIREMENTS:
1. Fully Rooted with Superuser and BusyBox 1.19.4. If you install Root-Script:
2. Please update BusyBox Free (Stericson) to v7.8.2 on PlayStore.
3. Proceed to BusyBox Installation. Install BusyBox 1.19.4 to SYSTEM/BIN directory.
4. Reboot Tablet.
5. Launch SuperUser and goto Preferences. Tap SU Binary Update
6. It will fail on 1st time, just Try Again until all text are Green
7. Reboot Tablet.
8. Internet Connection for PORN! -LoL
INSTRUCTIONS:
1. Connect Tablet to PC powered-ON and enable USB Debugging & Stay Awake.
2. Run V6_SuperCharger-Pull-Push-Script and Follow Instructions.
3. Select Option-#1 first and when done, do not EXIT the Script yet!
4. Upload Services.jar inside "ICS/default" Script Folder to http://android.mimic.ca
5. Download the Modified Services.jar and put inside "ICS/modified" Script Folder.
6. Proceed to Option-#2 and Reboot Tablet.
7. On your Tablet, download and install "Script Manager by DevWom".
8. Launch Script Manager and tap "Browse as Root" and check "Do not ask again".
9. It should ask for SU Permissions. If not, the script won't work.
10. Locate the "V6_SuperCharger_Update9.sh.pdf" and tap to open using Script Manager.
11. Once you get on V6_SuperCharger_Update9.sh.pdf menu, TAP to ENABLE [SU]
12. Leave the OTHER options at DEFAULT. Hold your Tablet to PORTRAIT MODE.
V6_SUPERCHARGER MENU #1: BASIC SETTINGS
1. TAP the [RUN] button. V6_SuperCharger_Update9 Script will now RUN.
2. If asked for "Scrolling Speed", select [FAST]- Type= 1
3. If asked to "Disable Animation", select [YES]- Type= Y
4. If asked to "Apply SuperMinFree Calculator Settings", select [YES]- Type= Y
5. Follow the succeeding "Script Instructions" and it will ask if you want:
6. TO perform [SuperClean and Restart], select [YES]- Type= Y
7. Tablet may look like in Boot-Loop, but it is not. Just Try ON/OFF atleast 3x.
8. If successful, you can skip performing V6_SuperCharger Menu #2.
V6_SUPERCHARGER MENU #2: RECOMMENDED SETTINGS1. TAP the [RUN] button. V6_SuperCharger_Update9 Script will now RUN.
  • If asked for "Scrolling Speed", select [FAST]- Type= 1
  • If asked to "Disable Animation", select [YES]- Type= Y
  • If asked if "Launcher is at Home", select [YES]- Type= Y
  • Press any Key to Continue. If Browser pops-up, just press BACK once.
2. On V6_SuperCharger MENU, select [SuperCharger & Launcher]- Type= 13. Wait until it finish and Press any Key if asked to do so.
  • If Browser pops-up again, just press BACK once.
  • You'll be redirected again to V6_SuperCharger Menu.
4. On V6_SuperCharger MENU again, you have the Following Options:
  • If Tablet has 512MB RAM, Select [Super UL -512 HP] Type= 7
  • If Tablet has 1GB RAM, Select [Super UL -1000 HP] Type= 9
5. Wait until it finish and Press any Key if asked to do so.6. You'll see something like "100% SUPERCHARGED" if its Successful
  • Select [SuperClean and Restart]- Type= 30
7.Tablet may look like in Boot-Loop, but it is not. Just Try ON/OFF atleast 3x.
  • We're not DONE YET! Please follow below Instructions:
LOAD 99SUPERCHARGER.SH ON BOOT:
1. Launch Script Manager and press Back Key twice until you reach [/] Directory.
2. Open /Data and look for 99SuperCharger.sh, tap it to select and run using Script Manager.
3. Select [SU] and [Boot] and hit the RUN button. After finish, just close it.
4. Enjoy V6_SuperCharger - Super-Saiyan Mode.
5. Do not uninstall Script Manager. It is used by 99SuperCharger.sh every Boot-up.
DEVICE NOT FOUND ERROR?:
1. Extract USB_Driver to a Folder and Connect Tablet to PC powered-ON.
2. Go to Device Manager. Check for an Android Device with Exclamation Point [!].
3. Right-click Android Device and click Update Driver. Locate the USB_Driver Folder.
Credits to zeppelinrox of XDA [Creator of Amazing V6_SuperCharger Script]
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
2012/07/11 - 01:07
Thanks to both If you, a Very good find and admin Thanks for posting everything right here for us. I can't stress following ALL the drections to the very END! I somehow missed the last If loading /data/99SuperCharger.sh. Don't know how but I did. A notice kept poping up every few seconds till I corrected it. Running smoother.
lohtse
Forum Posts: 157
2012/07/12 - 11:10
Hmmmm did as instructed and now all apps installed to sd nolonger show up!!!!!!! And tablet soooooooooo slow n sluggish its nearly unusable too! oh and the tablet keeps rebooting after its loaded up too!!!! first reboot was before I had chance to apply any settings recommended above... since then no stable tablet
well I restored the original Services.jar  and deleted the supercharger folder data folder but still get reboots as soon as the tablets loaded up. Even removed sd card but soon as system finishes loading up REBOOT!... NOW at a loss as what to do next....
I have a tablet that is unusable and no Idea how to fix!
2012/07/12 - 12:15
I haven't had time to check these scripts on the 7 G3, still busy to get Google Play setup on Arctools, I'll try check that soon.
Maybe ALD3 has some ideas to help you ?
In the worse case, I suppose you can flash the Hyundai A7 firmware to get everything back in place.
lohtse
Forum Posts: 157
2012/07/12 - 12:31
problem with worst case is if no official firmware becomes available and tablet Dies then can't return for replacement etc...It's annoying as deleted Dalvik cache, removed all Supercharger data/folders and even script manager as well as restoring original file(services) and still no joy..... All's well untill it finishes loding the system in and then REBOOT!
The only thing thats been installed in script manager and Supercharger but where ever the changes are it's just seems impossible to restore the originals... I suspect what ever the changes are are linked between Supercharger and the SDcard as it's when itfinishes trying to load the apps installed to sd when the reboot seems to occur...
Can confirm its happens only with SDcard inserted!!!
So this would suggest its corrupted either the Apps folder or data folder grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
lohtse
Forum Posts: 157
2012/07/12 - 14:37
Arrrrrrrrrrrrrrr CR*P!!!! sorry
well tablet nolonger boots up it's now stuck at arnova boot screen.... Have tried deleting (Via android commander) dalvik and data folders and no joy.... even restore the org vold.fstab file and nothing!
Basically what ever messed up during the reboot when trying to apply the settings for supercharger has really messed the system up....
Don't wish to flash the Hyundia A7 rom as may have to return to Currys!
2012/07/12 - 14:40
Can you still access the tablet thru ADB ? maybe restoring /system partition is worth a try, though I'm not yet sure on the best way to proceed.
lohtse
Forum Posts: 157
2012/07/12 - 15:08
yep have adb access....
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
2012/07/12 - 21:09
This is probably the file you need to delete
Open /Data and look for 99SuperCharger.sh, generated by script manager and looked for at boot up. Look at the last steps on the orginal directions. Mine too has gotten very sluggish on the net, no matter what browser I use.
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
2012/07/12 - 22:23
See if android commander will go to root, even if stuck at ARNOVA bootloop. I have been able to access root from there using android commander. If so go to root/data and delete the file ,
99SuperCharger.sh. It looks for script manager on boot.
a_elizondo
Forum Posts: 22
2012/07/13 - 01:52
can you read the sdcard thru ADB by searching for /mnt/sdcard or /mnt/extsd (not sure if you modified the mount to have your sd card be in /mnt/sdcard.
BTW I returned my tablet with the hyundai firmware since mine had a faulty usb connector (internally) and would not charge with no problem, but this may depend on stores.
lohtse
Forum Posts: 157
2012/07/13 - 10:05
yep had done all that and still no joy(one of first things I did) has sat all night at boot logo..
lohtse
Forum Posts: 157
2012/07/13 - 10:07
yep can but as above still sits at boot...
lohtse
Forum Posts: 157
2012/07/13 - 10:22
re ran adb mount command and it does not show sdcard or extsd mounts anylonger......
116 Guest(s)
Devices in use: Desktop (79), Phone (37)
altzes
naim
jorgebbbbb
souileh
DonQuinn
q.in.c
Topics: 6028
Members: 261301
