USB Host? But how?!
Tags: USB host
Related Tags
ninjaduck
Forum Posts: 54
Thanks Received: 8
2012/06/25 - 19:28
So I was stumbling through the settings last night, and I noticed that under "Storage" there's a subsection that allows you to choose to enable USB Host mode and media scan.
This thing will support being a USB host?!  This leads to my question,
who on earth makes a Micro USB-B (male) -> USB-A (female) adapter cable?!
The very thought is absurd, as it scoffs in the face of the purpose of the different-sized (and gendered) plugs.
So, does anyone make such a cable?  Has anyone gotten their G3 tablet to function as a USB host?  What did you connect?
Thanks Received: 3169
2012/06/26 - 00:47
Archos make some USB host cable, they are usually named as USB host or USB OTG cables. There are also some cheaper cables from Nokia, I believe it's the CA-157 model.
With these cables you can usually connect a 3G Dongle (I think Archos 3G Stick is supported on all Arnova G3 tablets, you can also check here for a test on an Arnova 8 G2), USB keyboard or mouse and some hardisks or USB sticks for storage (not all model work).
arrasmith
Kansas, USA
Forum Posts: 65
Thanks Received: 7
2012/06/27 - 00:22
You need a Micro USB OTG Host cable. I got ones from amazon awhile ago that work fine. Just ordered some more from newegg because it is easy to lose cables like these. :-/
On my 7 G3 I've used flash drives and a wireless keyboard/mouse combo. On my Archos 8 G9 I've also used a 2TB external hard drive. So I know they work.
lohtse
Forum Posts: 157
2012/06/27 - 12:07
was just about to confirm as above but my Adapter came rom ebay for 79p in p&p...
TezSK13
2012/06/28 - 12:05
these cables are real easy to make as well if ya got a steady hand,spare micro usb and usb extension cable
SupArnova
Lubbock, T.X.
Forum Posts: 33
2012/06/28 - 17:01
Arnova 8 g3 - kasty-arn8g3-40-042:::
Arnova 7b g3 - kasty-arn7bg3-40-042 :::
ChildPad - kasty-arnchildpadr-40-04 ::: LG Optimus s - Reborn rom 2.2.4 :::
67 Guest(s)
Devices in use: Desktop (62), Phone (5)
Raztas
Hakuna
vitor lopes
Michal Senger
Franco Ciccio
cicciu76
Members: 262047
