2012/07/09
Good News!!!.
After hours of research, I found the simple solution to fix the 'internal storage' error.
The factory reset did delete /system/bin/busybox which doesn't mount the /data and /cache partition after reboot. Simply copy the /system/xbin/busybox over /system/bin/busybox using rootexplorer which solves the issue.
God. I saved lot of people's time... 🙂
2012/06/12
vaidyasr said
AALD3 said
vaidyasr said
I also had a similar issue. Can't install any apps from market. Manual installed apps via APK gets deleted upon reboot. Can someone please help by posting their files under /system/app directory?. I have un-installed the applib...
Not sure what apks your having trouble with but if its Google play, then download the zip posted in An 7 G3 Google play setup by lohtse, post number 4. I installed the ones that would install and then copied all files in the zip to /system/app/ folder and then rebooted. All worked great and when I did a factory restore/reset the apks were still installed and in my apks menu. Before you do this, I think that I would go into tablet setting menu and in Privacy do a Factory Restore /reset and start fresh.
Already tried the reset and no difference. I think I found the issue. Can someone please send the content of /proc/mounts file?. This can be done by using root explorer.
Here is the file you requsted from proc/mounts, from my dropbox.
2012/07/07
vaidyasr said
Good News!!!.After hours of research, I found the simple solution to fix the 'internal storage' error.
Yes, they are 🙂
It works, that's fantastic.
2012/06/17
How did you do a factory reset on the 7g3 as my daughters is stuck on the ARNOVA boot screen, it won't go any further so I'm guessing a factory reset is my only option.
It had the stock rom as no changes were made to it when purchased.
Thanks.
2013/02/05
i cant able to copy that file its not mooving i tried everything how u moved
126 Guest(s)
Devices in use: Desktop (122), Phone (4)
