2012/06/24
i tried to restore the device to fabric configurations but while it was restoring something happend and the android logo changed to another android logo with an exclamation mark... now i can't install any app because it says that there isn't free space... apps like Update or Appslib dissapeared... i haven't got the serial number (at least it doesn't appears in settings)... and anytime i shut it down, it restores...Â
what do you think about change the firmware? --->Â http://www.flashmyandroid.com/forum/showthread.php?415-ROM-Hyundai-A7-Firmware-ICS-4-0-3-20120405-Elvish-0-3
sorry about my english... if there is anyone who speak spanish please let me know...
thanks
2012/02/02
sorry your tablet 7G3 is not working correctly... Have you tried going in to settings and doing a factory reset? Have you still got root access? If you have root access try deleting the data/data and dalvik folders as I has a similar issue on my not dead arnova 8G2 and thankfully it solved it....
other than that may be give the mentioned rom a try and hope an official 7G3 rom appears soon....
It won't be an official firmware, but I should have a 7 G3 firmware dump ready in the coming days.
2012/02/02
2012/06/12
lohtse said
other than that may be give the mentioned rom a try and hope an official 7G3 rom appears soon....It won't be an official firmware, but I should have a 7 G3 firmware dump ready in the coming days.
A rom dump would be super. I also would like to know how to dump a firmware.
Thanks Admin
2012/06/24
lohtse said
sorry your tablet 7G3 is not working correctly... Have you tried going in to settings and doing a factory reset? Have you still got root access? If you have root access try deleting the data/data and dalvik folders as I has a similar issue on my not dead arnova 8G2 and thankfully it solved it....Â
that's what i did... i did a factory reset but when it was resetting it crashed...
i lost the root access, so there weren't too much to do
I just couldn't wait jeje so last night i installed the firmware of the hyundai A7... it works nice, but only the rotation of the screen doesn't work... Â
Now the bootlogo is different, obviously, but some configurations like languaje, wifi's networks and some other things are just like them were before the issues... (sorry i hope you could understand what i tried to say)
That's would be awesome... I'll be waiting for that...Â
Is too hard to modify firmwares? What do you need to do that?Â
thank you all..!
thank you all..!
I hope you're not too much in hurry, as it should take me quite a few days before I work on that.
Modifying Rockchip firmwares (used on other Arnova tablets) is now quite well documented, is not too hard to do , it's easier when you have some Unix scripting knowledge.
As for Boxchip Allwinner stuff (specific to the Arnova 7 G3), I don't know as I haven't started yet, there are quite a few web resources on the subject, so I'm not worried.
http://forum.xda-developers.com/showpost.php?p=22397975&postcount=5
https://github.com/zenitraM/a10tools
http://elinux.org/Hack_A10_devices
I'll update here as firmware work progresses.
2012/06/02
Do you have any links on how to do a firmware dump? Thanks for all your work on these tablets.
2012/06/29
I am having the same problem as the original poster. Is there anything I can do to fix it?
Here is a screen print of my Internal Storage screen. Top partition shows Zero Total Space, bottom shows 2.0GB. How can I get the top portion back? I cannot install any apps due to insufficient space.
arrasmith said
You can have a look at this page:
I haven't tried it yet though.
The batch file uses the fact the tablet is rooted to dump the nand partitions on the sdcard. The path where the dump files are stored may need to be adjusted on the 7 G3.
2012/06/29
I am also getting "tutorial screens" when it boots up about how to put my favorite apps on the home screen. Am I stuck in some demo loop?
75 Guest(s)
Devices in use: Desktop (67), Phone (8)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
