Overclocking the 7G3
lohtse
Forum Posts: 157
2012/06/27 - 12:12
everytime I have set above 1.1ghz it becomes unstable... either reboots it's self or get a grey or even blue screen and only way to fix is a reboot...   tried on both our tablets(7G3) and always same results.....  Having said that it does't happen straight away and can be anything from 5 mins to 2 hours before it happens..
ninjaduck
Forum Posts: 54
Thanks Received: 8
2012/06/29 - 17:51
SetCPU or CPUMaster?  What governor?
Mine is comfortably stable @ 1246mhz max, 30mhz min, fantasy or interactive governor, using CPUMaster
No reboots at all until I tick it up past 1246.
lohtse
Forum Posts: 157
2012/06/29 - 19:51
SetCPU
ninjaduck
Forum Posts: 54
Thanks Received: 8
2012/07/02 - 19:05
Might I suggest CPUMaster, then?
debkol35
Forum Posts: 44
2012/08/23 - 19:24
sir,
Can u tell me if overclocking will reduce battery life fast?
ninjaduck
Forum Posts: 54
Thanks Received: 8
2012/08/24 - 18:18
Slightly, while in-use.  The battery was "designed" for the unit running at 1000mhz.  I don't think there's a direct 1:1 correlation for increased power consumption, but I'd say when I bump mine up to 1200mhz it lasts about 20% less
However, my standby power consumption dropped dramatically.  I can leave it on, asleep, for about 3 days and come back to 40% battery.
Use AnTuTu CPU Master, fantasy governor, 30mhz minimum, 1200mhz max (or the next setting below to be safe), set on boot, and make sure to enable to "bypass if quick reboot" option under settings.  This way if you mess with an overclock setting and it reboots your tablet, you can choose "Skip It" on the reboot to not get stuck in an error-bootloop.
I've got no complaints.  Only Flash webpages have been able to crash my tablet since putting in these settings.
debkol35
Forum Posts: 44
2012/08/24 - 21:30
Thank u sir. But before ur post, I already installed setcpu and set cpu at 1152 mhz and 30 mhz. It looks like workig fine so far. Browser is not crashing. But still want to ask that is there any posibility that the tablet wifi maynot work properly? I am not sure if I am getting wifi signal I used to get beforr it! Pleasy reply. Thxxxxxxx
debkol35
Forum Posts: 44
2012/09/02 - 18:05
back to normal settings.... being lagged a lot.. :(
58 Guest(s)
Devices in use: Desktop (53), Phone (4), Tablet (1)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
