Overclocking the 7G3
lohtse
Forum Posts: 157
2012/06/06 - 19:12
Well Folks we Overclocked the 7G3..................................
And then removed Overclocking and returned to defaults..
We used Setcpu to be able to overclock...
The only stable(ish) OC settings was below 1.1ghz, Anything above that resulted in a grey screen or the 7G3 rebooting it's self. We tried ondemand,interactive heck pretty much all the govs and none produced any better results…
On down clocking to 1.1ghz and below(inc default) the 7G3 became less responsive then before overclocking and there was or at leasted seemed a slight lag too. We found menus took a second before appearing and as for games and menu/launcher transitions well they stuttered a little and constantly..
Basically we found that the 7G3 doesn't like too play nice after overclocking so uninstalled setcpu and reverted back to default and all's well again..
My advise at this time. Just don't bother till a custom rom that better supports OCing comes along..
Or if you have some ideas as to how to achieve a useable and stable overclocking of the 7G3 then post it here for all to try!
regards
Lohtse
Edit.....
Reinstalled SetCPU
set governor to fantasy
1152mhz max
and all seems well for the moment.......
lohtse
Forum Posts: 157
2012/06/06 - 19:50
The best settings for overclocking the Arnova 7 G3 are below..
Use SetCPU of market and set as follows:-
Set governor to fantasy
and speed to 1104mhz...
So far I have a slightly speedier and snappier 7G3 and without hickups etc...No stuttering or lag....
If you find a better setup then let us all know..
regards
Lohtse
The following users say thank you to lohtse for this useful post:
hodged02
lohtse
Forum Posts: 157
2012/06/07 - 18:32
24hrs on and the settings above are the most stable..
Have tried upping the speed but always reboots or get grey screen of death..
Will stick with the settings mentioned for now..
tank27
Freak CIty/New Orleans
2012/06/09 - 02:50
would overclockling help my netflix playback at all?
lohtse
Forum Posts: 157
2012/06/09 - 10:23
may do but it just may be the wifi...as netflix is fine for us.... also update flash....
tank27
2012/06/09 - 12:18
It works just stutters a bit.  im sitting less than 10 ft from my router.
ninjaduck
Forum Posts: 54
Thanks Received: 8
2012/06/11 - 19:07
Overclock report-
AnTutu CPU Master (free), min 30mhz max 1246mhz (or is it 1248?), interactive or fantasy governor
stable like a boss.
also, Swapper 2 (puzzle-piece icon) running on micro-SD improved my Netflix streaming performance
but on the whole, it has very sub-stellar wifi reception.... maybe an official firmware update could help (just don't un-root us dammit Archos! that was really convenient!)
soulfox
2012/06/12 - 00:13
hi ninjaduck
overclock setting, tried but wont set ? just reboots and sets it to 1008mhz, gone back to 1104mhz/fantasy.......
andy
ninjaduck
Forum Posts: 54
Thanks Received: 8
2012/06/12 - 00:40
Are you using setcpu or cpumaster? Do you have superuser installed correctly? Ultimately it may take a custom ROM before some devices can be overclocked, as a custom kernel may help stability.
ninjaduck
Forum Posts: 54
Thanks Received: 8
2012/06/12 - 02:11
On a separate note, make sure you only use the original AC adapter to charge the tablet...I had mine plugged in with my phones adapter and the screen was flickering...too much juice.fortunately no permanent damage.
lohtse
Forum Posts: 157
2012/06/12 - 10:56
tried AnTutu CPU Master but after a while I had same issues as mentioned before when set over 1108mhz..
As superuser is working correctly for all other apps it would suggest it is the Kernel not the application... As to swapper2 main issue with swapper I have always found is that if the tablet reboots randomly the swappers partion becomes corrupt and the you spend eons trying to sort it out as the tablet or phone takes a century to become usable..
Anyway I have had no issue with netflix without it
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
2012/06/12 - 15:59
I didn't see ninjaduck's charger comment till after but charged 7G3 using the charger for my Galaxy SII Skyrocket. Used it both with 7G3 on while using it and turned off over night. No flickering screen and no problems. I wouldn't have used it if I had read ninjaduck's comment. Since I have, thought I would pass the info along.
Thanks for all the valueable info here on the 7G3!!!!!
Laugh
ninjaduck
Forum Posts: 54
Thanks Received: 8
2012/06/13 - 04:26
As long as your adapter doesn't crank out substantially more mW than the arnova you should be fine, mine was pumping an extra 450
juanche777
2012/06/25 - 16:01
I'm one question because arnova 7g3 working a 1.0 Mhz and hyundai 7 working a 1.5 Mh??
Thanks Received: 3171
2012/06/25 - 16:03
Both devices (Arnova and Hyundai) are supposed to run on the same hardware, maybe there are some clock difference in their firmwares.
Tests done in the forum show the Arnova is reasonnably stable up to 1.2 GHz.
89 Guest(s)
Devices in use: Desktop (84), Phone (5)
heftpflaster
rk.13
