Restoring original Arnova 7 G3 ROM
kuper
2012/08/31 - 19:33
Hi! So I've updated my Arnova 7 G3 to elvish 0.3 and, as you all know, it has a problem with the acelerometer. Since I realy need that function working on my tablet, how can I return into the original ROM?
I've been into "original dump firmware" post in the forum but haven't understand how should I do it.
Help needed please!
Regards
Joao Cabrita
Thanks Received: 3169
2012/08/31 - 19:42
Hello Joao,
This is a work in progress.
I will check the files ninjaduck has provided and confirm it works. Hopefully other forum members can help testing as well, creating batch files to automate the firmware procedure or documenting it.
debkol35
Forum Posts: 44
2012/09/01 - 09:42
just for curiosity ...what does ROM update do? and Does it help to update Android OS version?
debkol35
Forum Posts: 44
2012/09/01 - 12:03
I was looking at google..and found a tool known as ROM Manager ...Can't we backup our 7 g3 ROM before updating to another rom?
Thanks Received: 264
2012/09/01 - 12:29
No, you need a clockwork recovery
debkol35
Forum Posts: 44
2012/09/01 - 12:33
sir, any good ROM available for 7 g3 ? kuper saying elvish 0.3 has some problem... !!
2012/09/01 - 13:02
the work is in progress, admin will release a new firmware based on the stock one.
debkol35
Forum Posts: 44
2012/09/01 - 13:05
wow woww...that is a great news...  :) LaughLaughLaugh
kuper
2012/09/01 - 13:32
debkol35: Yes, it seems it has a little bit more lag on multitasking but maybe it's the apps that i'm using.
Anyway, it doesn't have the acelerometre working and if you really need it, it sucks.
globula_neagra and admin, that's some good news! i'll be looking foward to check that!
Thanks for the replies guys!
Regards
2012/09/01 - 13:43
o person allready returned to the stock firmware, check this topic for more info http://www.arctablet.com/blog/forum/arnova-7-g3/original-firmware-dump-anyone/page-5/
kuper
2012/09/08 - 13:35
Well, just delivered mine to Warranty.. let's see what they have to say.
(only thing said: "Auto-rotate doesn't work" :P )
92 Guest(s)
Devices in use: Desktop (83), Phone (8), Tablet (1)
mansour
napkiraly
ahmedsaad
tiagoz
celinedeuxsevres
15djamal15
Topics: 6015
Members: 260841
