Arnova 7 G3 firmware dump (restore your device to stock)
m0dcm
Forum Posts: 17
Thanks Received: 4
196
2013/04/30 - 02:14
After messing up my Arnova 7G3 just over 24hours ago, I'm now fully back up and running thanks to a man who, spent over 2 and a half hours remotely connected to my PC and working his fingers off to get it working again! This person is none other than @globula_neagra and he explained everything what he was doing and also put up with my accidently rebooting the device!
I didn't realise how much I missed this low end Tablet PC, as I use it on a daily basis, esoecially when I'm not in front of my PC, and also when my disability really gets the better of me, and I'm stuck in bed, I'm still able to keep in touch with friends and family, but anyway, this post is to thank this guy so much!
If anyone has a so called "Bricked" Arnova 7G3, and @globula_neagra has the time, he will try his best to fix it! I'm now running the latest stock firmware dump from the first post, and the device seems to run quicker than before!
Big thanks also to this Website and Forum, for if it wasn't for you guys, we Archos & Arnova Tablet PC owners would have to go elsewhere and have to put up with the dreaded Appslib!!
The following users say thank you to m0dcm for this useful post:
Tablet PC - Arnova 7G3 with Factory ROM -
PC - Zotac Z-Box AD01 with Ubuntu 12.04LTS
Detection
Forum Posts: 22
Thanks Received: 5
197
2013/06/26 - 12:30
So a couple of days ago, I flashed Elvish and then the G3 ROM dump files and all went well
Unfortunately now, no apps are working, they all just force close as soon as they open
Does anyone have experience of this happening or a solution ?
I've cleared the Dalvik-cache folder and rebooted, but that didn't seem to do anything,
Any ideas would be welcome, thanks
tr03
198
2013/08/25 - 17:06
My tablet was locked and for two weeks I can not get to the unlock
I tried to understand this topic but I do not understand
could someone explain to me how the unlock or give me a little tutorial
Thank you ..
P.S My English is not very developed
Detection
Forum Posts: 22
Thanks Received: 5
199
2013/09/22 - 21:23
Ive read somewhere in this forum about a fix for the disappearing internal storage problem after a factory reset ?
I can't find it anywhere, could someone link me to it please?
I reset the tablet, and now internal storage says 0.00 bytes and I can't install anything
I've tried resetting it again, but no luck
Detection
Forum Posts: 22
Thanks Received: 5
200
2013/10/05 - 08:36
Ok, I worked out the problem, turns out "Busybox" causes the 0 bytes storage issue, making the tablet boot up in first boot welcome mode
Removed busybox via adb, reflashed the 4 images, removed busybox again normally, all is good again
weedoverdz
201
2014/04/14 - 16:55
hi detection i have the same problem as you . but i don't know how to remove busybox with adb in linux . i'm using ubuntu 12.04 64 bit . i have install the playstore with the arctools method everything was working fine but my brother accidentally uninstall  busybox know i'm stock with a device who have 0 bytes of storage i can't install any app but everythink else work fine if somebody can help me . thanks ps: escuse my english i speak french
Detection
Forum Posts: 22
Thanks Received: 5
202
2014/04/14 - 17:07
I had to reflash the 4xROM images over the top to fix it from Ubuntu OS
Nothing lost, but Android storage was fixed
The following users say thank you to Detection for this useful post:
weedoverdz
weedoverdz
203
2014/04/16 - 00:38
Thanks . but i'am strugglin a lil' bit  i found the 4 img, but if you can tell me how to reflash those files it will be great Smile.Do i need to use virtual box and rockchip tool or adb in ubuntu os .escuse my rubbish English
Main OS ubuntu 12.04 lts 64 bit
Detection
Forum Posts: 22
Thanks Received: 5
204
2014/04/16 - 00:45
Im just looking for the instructions, I posted them on this site a while back after finding them originally here too
Ive just searched my drive for them and came across a text file named "Arnova Storage Error" - and it says the following:
copy the /system/xbin/busybox over /system/bin/busybox using rootexplorer which solves the issue
Note: there is an X in the first dir location of Xbin and not in the destination dir location
Give that a shot first while Im looking for the reflash instructions
You'll likely need to reboot afterwards
weedoverdz
Detection
Forum Posts: 22
Thanks Received: 5
205
2014/04/16 - 00:52
Found it: - These are the main reflash part of the instructions, you don't need the first half as your tablet is booting up ok and they are only for bricked tablets:
Best done in Ubuntu - Commands are the same
12. Start up everything on your device. Ignore all the settings for now.
13. Use your filemanager to double check directories for mounting
14. Copy the nan files to your MicroSD card and put it into your device.
15. open command prompt in windows.
16. Connect your device to your pc and set debugging on in Developer Settings on your device.
17. In command prompt go to your adb directory and type this:
    – adb device
this should show if your device is visible
then type:
adb remount
adb shell
You now have your devices terminal open in prompt
Now starts the fun part.
18. type:
cat /mnt/extsd/nanda.img > /dev/block/nanda
cat /mnt/extsd/nandb.img > /dev/block/nandb
cat /mnt/extsd/nandc.img  > /dev/block/nandc
cat /mnt/extsd/nandd.img  > /dev/block/nandd
(sometimes this takes a while for the prompt to register but wait until your # shows up before entering each command)
19. type:
sync
20. hold:
CTRL+C
21. type:
adb reboot
http://www.arctablet.com/blog/forum/arnova-7-g3/elvish-rom/page-2/#p25732
With section 18, you might find you need to modify the location of the files to match your device, it's been a long time since I did this but I vaguely remember having to do something like that - if you're running Ubuntu as your main OS you shouldn't have any problems working out what needs changing
Good luck
weedoverdz
weedoverdz
206
2014/04/18 - 16:35
detection thank you so much you are a boss . work like a charme
Detection
Forum Posts: 22
Thanks Received: 5
207
2014/04/18 - 17:18
Great :)
weedoverdz
juanche007
208
2014/08/10 - 18:09
Yeap after a year my arnova gathering dust in a drawer and I could solve it alive again I thank you, thank you. but I had to replace sdcard extsd for every step. but right now I have again one arnova 7 g3.
twenty4seven
209
2014/12/23 - 03:13
Thank you.  It worked fine with LiveSuit 1.11, elvish for A7-03 img, 15 seconds ADB installer v 1.3, Android USB drivers, NANDA.img through to NANDD.img files and the wonderful instructions given on here. :)
LonelyWolf
210
2015/11/05 - 08:40
Hi all, sorry for resume this old post, but i need an answer.
This firmware is working on a 7h g3?
Thanks.
51 Guest(s)
2 Guest(s)
Devices in use: Desktop (45), Phone (6)
thanhgom2006
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
