Arnova 7 G3 firmware dump (restore your device to stock)
ck2012
Forum Posts: 23
181
2012/11/17 - 16:03
Thanks for the reply ALD3, I put Elvish on it instead which is fine for my young daughter, I really appreciate your help tho.
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
182
2012/11/17 - 16:19
No problem, you can still go back at anytime. That's the important thing. Good Luck. I no longer have my AN 7 G3 but will still monitor this forum and help if I can.
The following users say thank you to ALD3 for this useful post:
ressoneca
Ishtar
Forum Posts: 16
Thanks Received: 6
183
2012/12/05 - 20:20
Just wanted to let you guys know that I re-flashed everything using the complete dump and it works as it should now. Sorry if it took a while, been busy...
The following users say thank you to Ishtar for this useful post:
ALD3, ressoneca
mhnd
184
2012/12/12 - 08:40
my device is locked (too many pattern attempts)
which image file (a,b, ...i..) can unlock it? or i should update with all files from the same dump?
Thanks Received: 3177
185
2012/12/12 - 16:13
You need to flash elvish firmware for Hyundai A7, as explained earlier in this post:
Download here: http://androidtabletfirmware.com/firmware_details=MzQ2LTEzMzM4MjMwMzE3Nzg5NDU2Nzk0
or thru our mirror: elvish-for-a7-0.3.zip
You'll need LiveSuit to flash this firmware:
Download: LiveSuitPack_v1.07.zip
This elvish firmware is OK the only problem is the accelerometer not working. From there, you can always flash back the default Arnova 7 G3 firmware from the stock firmware dump that ninjaduck / ALD3 have provided, see earlier pages in this thread.
mhnd
matijapkkape
186
2012/12/19 - 00:05
its impossible to instal cwm i downloaded lastest and try to install it with terminal but it says,,cannot create /dev/block/nandg: Premission denied....does it need root or??i think 7g3 is rooted out of box...please help
mhnd
187
2012/12/19 - 08:35
i did what mentioned in http://www.arctablet.com/blog/forum/arnova-7-g3/original-firmware-dump-anyone/page-5/#p12459
but when i try to make SYNC i get:
/system/bin/sh: sync: not found
any help please? and what is SYNC for?
thanks
Thanks Received: 268
188
2012/12/19 - 12:37
sync is sinchronizing the the data from the what you copy to where you copy and makes it identical and also ensures that everything was copied well.
ressoneca
Portugal
189
2013/02/24 - 13:31
Hi everybody, i've an Arnova 7 G3 that is not working well. as i'm not good at this things of development, i search a stock rom to flash it. the only thing i understood from all this posts (my english is not good) is this Arnova7G3_stock_kernel_compiled.zip (by admin, thanks) is the stock rom for it, bit it contains 4 img files... How can i flash it with LiveSuit ?
Life is for living and living is free
190
2013/02/24 - 13:41
Unfortunately, this can't be flashed with LiveSuit, you need to restore each partition with shell commands as mentioned earlier in this thread.
If you want a LiveSuit option, you can restore Elvish firmware, that works reasonably well on the 7 G3 (it has some incompatibilities with the accelerometer)
ressoneca
ressoneca
Portugal
191
2013/02/25 - 17:40
Ok, I'v flashed elvish-for-a7-0.3.zip and it's working well except for the screen rotation. But it's working better than it was. Thanks for the reply admin.
mhnd
192
2013/03/04 - 12:57
today i saw this page:
http://www.arctablet.com/blog/archos-tablet/arnova-kernel-sources-released-for-nearly-all-g3-models-10g2/
and there is "GPL release for AN7G3"
is this page new or old? and does it contain the right image for our tablet, anybody tried it? and how to use it?
thanks.
Ishtar
Forum Posts: 16
Thanks Received: 6
193
2013/03/04 - 13:38
Kernel sources will be useful if anyone wants to do further development / bug fixes. But we're already running that kernel so there's nothing to "try".
mhnd said
thanks.
m0dcm
Forum Posts: 17
Thanks Received: 4
194
2013/04/29 - 01:52
Hi Guys,
I've just screwed my AN7G3 up by uninstalling BusyBox!! I know silly me, so I'm going to attempt to re-flash it with the link on the first thread using my wife's Windows Netbook later this week. I know I could do it with my Linux PC. but there's too much to edit config files etc.
The only question I have, well 2, is how long will the process take? and the other question is has anyone had any success with making a single file for the ROM? I'll keep you all posted with how it goes, and the only reason I've chosen the stock ROM is I'd like the auto rotate etc to work as I play a few games, and view websites.
Tablet PC - Arnova 7G3 with Factory ROM -
PC - Zotac Z-Box AD01 with Ubuntu 12.04LTS
195
2013/04/29 - 02:07
The same amount of configuration is needed on both OS-es
You need adb in linux, and also on windows, but bare in mind that Linux handles better the adb drivers then Windows, especially Windows Vista which is crap in terms of drivers :) .
It should take 10-20minutes
A script could have been made to make the flashing more easier.
m0dcm, weedoverdz
51 Guest(s)
Devices in use: Desktop (48), Phone (3)
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
xstouf
