Arnova 7 G3 firmware dump (restore your device to stock)
Ishtar
Forum Posts: 16
Thanks Received: 6
166
2012/10/23 - 15:00
I didn't reflash it but I used install.bat. Everything worked in it, was able to do backups and such... but when you hit the factory reset/wipe option, you have no way to scroll up or down to confirm; so when you do a reset in the unit it just boots in CWM and waits there, and you can't do the wipe manually :(
I'll give it another shot later today.
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
167
2012/10/26 - 15:02
I just did a factory reset from within settings/backup&reset, it worked fine. Maybe you need to flash nandg which is the recovery img. I can use both cwm and stock recovery?
Ishtar
Forum Posts: 16
Thanks Received: 6
168
2012/10/28 - 00:31
Same thing again... it ran out of power, and factory reset itself. Quite annoying... guess I'll go back to Elvish, dammit :(
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
169
2012/10/28 - 00:42
Do you think it would help to flash all nand imgages a-i? I will upload the rest if you want to try nanda-nandi. Let me know.
Ishtar
Forum Posts: 16
Thanks Received: 6
170
2012/10/28 - 01:04
If you could that would be awesome! :)
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
171
2012/10/28 - 01:12
Have it already so will put them up. Hope it helps you.
here is
nandf https://www.dropbox.com/s/v0ktfh3g85f9d0d/nandf.rar
nandh https://www.dropbox.com/s/qih4zd0tlgjw173/nandh.rar
nande and nandi are 1 gig and 2 gig, they will be a little longer but will be up as soon as I can upload to dropbox.
admin can you possibe  host these after they're all up? nanda-nandd were already uploaded by me in my dropbox as was nandg, here is f&h with e and i coming as soon as they are uploaded to dropbox. I also saw where there was an nand1 but when i tried it kept saying file not found on my device. these are all from June 2012 AN7G3 software.
nande https://www.dropbox.com/s/4cd2gpezkcmkk64/nande.rar
The following users say thank you to ALD3 for this useful post:
Ishtar, Jorge
Ishtar
Forum Posts: 16
Thanks Received: 6
172
2012/10/28 - 01:32
Thanks a lot! I'll wait a little and mirror them all as well, I have a server that can hold them and manage the bandwidth.
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
173
2012/10/28 - 01:39
Thanks, still got about 15 min upload left on nanadi. Its 2.22g.
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
174
2012/10/28 - 02:13
nandi https://www.dropbox.com/s/34d8tqpjblc6gbn/nandi.rar
This should be all of them, let me know if your missing any and hope they help your problem.
Ishtar
Ishtar
Forum Posts: 16
Thanks Received: 6
175
2012/10/28 - 02:26
Thanks. Here's the mirror link:
http://arctablet.com:arnova@www.lethe.ca/arnova-7G3/
I'll try it tomorrow and let you guys know how it works out. I'll also add the missing files (I just mirrored the ones you provided now).
Edit: Added nanda-d from your original .rar.
The following users say thank you to Ishtar for this useful post:
ALD3
606613
176
2012/10/29 - 18:51
I want to make hard reset of my an7g3...
I'm reading all of your posts but i cant understant anything :(
Anyone can make video tutorial about HOW TO MAKE HARD RESET OF AN7G3???
It will be very usefull...
Thank U... and sorry for my English...
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
177
2012/10/29 - 19:52
There is a small hole on the same end as the power button , it says speaker. Press a paper clip in it till you feel.it press the reset button and while holding it press and hold the power button till it starts hard reset and then release both.
606613
178
2012/10/30 - 16:54
Thank U for your reply...
 I found that button, pressed it and holding it pressed the power button, but nothing happend... Only red light is turning on and thats all, screen is turned off... After that red light is turned on and dont turning off, i must to press and hold the power button to turn it off, and only after that i can turn my tablet on again...
I tried lot of combinations, like pressing this buttons with charger connected and removed, with tuned off tablet and turned on too :)  so i was pressing buttons all night long but nothing ... is there other way???
My english is bad but i hope U will understand everything.
ck2012
Forum Posts: 23
179
2012/11/04 - 17:36
My daughters 7g3 is stuck on the ARNOVA loading screen, I too tried the reset button where it says mic with the power button but I still get the stuck ARNOVA screen.
Any idea's anyone ?
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
180
2012/11/13 - 11:06
Any idea's anyone ?
If you hook up usb and your PC is able to install and see your tablet, then I would read tho this entire thread. There are nand imagine files and adb commands, so you can try to restore using adb. I believe that you only need the first four nand files, nanda, nandb, nandc and nandd. There are 2 sets of nand files, the first set and then a later set for devices bought after June 2012. Either will work but June 2012 is an updated version.
ck2012
Currently Online: thanhgom2006
43 Guest(s)
Devices in use: Desktop (41), Phone (3)
thanhgom2006
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
