Arnova 7 G3 firmware dump (restore your device to stock)
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
151
2012/10/21 - 04:29
ninjaduck said
ALD3 can you advise steps to get superuser working again on your firmware? App installs from play store but will not manage su requests.... everything bypasses it.
Hmmm, thought it was still in the dump like play and gmail. Are you Iinstalling superuser or supersu? I have found that with supersu not installed during a root process will not write the su in xbin. I would install superuser and update the su file with it, then install supersu and un-install superuser. If its superuser and you have installed, then reboot and run superuser. If it still won't make an su file in xbin. Then you might try putting an su file manual with es file explorer in system/xbin and then run superuser. I had no problem. Here is an su link in my dropbox, not from an7g3, as I'm not on it right now. If this su won't work then let me know and will get one from an7g3.
http://db.tt/7ZiKaeod
Don't forget that you must open superuser and update su file after install or it won't work. Ninjaduck, let me know if you get it to wôrk. Also admin installed but didn't say anything about superuser.
Ninjaduck, did you get superuser to work? Here is the su file AN7G3. Copy to system/xbin
http://db.tt/vPXbkoOL
Ishtar
Forum Posts: 16
Thanks Received: 6
152
2012/10/21 - 20:01
SuperSU worked fine for me on your dump, ALD3.
The following users say thank you to Ishtar for this useful post:
ALD3
ninjaduck
Forum Posts: 54
Thanks Received: 8
153
2012/10/21 - 21:59
Supersu worked, problem solved! Updating binary also probably would have worked. On another topic, I have been toying with porting elvish onto the g3's system files. Finally got it to work, but it offers no apparent benefits! However if a more feature filled rom is ever made for the a7 I now know how to port them :-)
Ishtar
Forum Posts: 16
Thanks Received: 6
154
2012/10/21 - 22:17
Any chance you could see if the problem with the auto-rotate is not simply due to a missing kernel module? It would be awesome if we could just import it...
Thanks Received: 268
155
2012/10/21 - 22:37
admin, Ishtar
Ishtar
Forum Posts: 16
Thanks Received: 6
156
2012/10/21 - 22:53
Or if anyone still has elvish installed... can you compare lsmod?
root@android:/ # lsmod
lsmod
8192cu 570686 0 - Live 0xbf099000
rtl8150 8910 0 - Live 0xbf092000
mcs7830 6557 0 - Live 0xbf08c000
qf9700 8513 0 - Live 0xbf085000
asix 22500 0 - Live 0xbf07a000
usbnet 23745 3 mcs7830,qf9700,asix, Live 0xbf06e000
sun4i_csi0 27537 0 - Live 0xbf063000
gc0308 13436 1 - Live 0xbf05b000
videobuf_dma_contig 5659 1 sun4i_csi0, Live 0xbf056000
videobuf_core 18067 2 sun4i_csi0,videobuf_dma_contig, Live 0xbf04c000
mali 130627 8 - Live 0xbf01f000
ump 42602 9 mali, Live 0xbf00e000
goodix_touch 12453 0 - Live 0xbf006000
mma7660 5671 0 - Live 0xbf000000
Thanks Received: 3177
157
2012/10/21 - 23:01
lsmod
mma7660 is the orientation sensor, but I dont really know how to make kernel module changes on Allwinner A10 based firmwares.
Anyway, with ALD3 latest firmware dump and ArcTools package, I think we have a good tablet setup, properly working with Google Play Store. I haven't yet done much tests thought.
Ishtar
Forum Posts: 16
Thanks Received: 6
158
2012/10/21 - 23:03
Yeah definitely this is a good stable firmware. And I'm a total newbie on android. But I'm thinking if this kernel is not that different from the elvish one, then maybe we can just load this module on the elvish kernel so the auto-rotate works...
Ishtar
Forum Posts: 16
Thanks Received: 6
159
2012/10/22 - 00:39
Can anyone provide nandg please? I forgot to back it up before installing CWM, and the only link here is 404 :s
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
160
2012/10/22 - 03:43
Here lshtar is the nandg from my dump, if you need any others let me know.
https://www.dropbox.com/s/tkyvxbmichuxkoz/nandg.rar
The following users say thank you to ALD3 for this useful post:
Ishtar
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
161
2012/10/22 - 16:04
So nanjaduck and lshtar or anyone else that has installed the new June 2012 AN7G3, How is it working, admin said he had foreclose on camera. Hope camera will work as it is much better then the original April 2012 firmware.Laugh
Ishtar
Forum Posts: 16
Thanks Received: 6
162
2012/10/22 - 16:07
I don't really use the camera honestly, so I can't say if there's a difference. But so far so good! I had wireless issues with the original firmware (would drop once in a while and had to reboot), hasn't done it yet so it appears fixed. General performance looks better too. I was just restoring apps now so I'll let you know for sure later, but it's looking really good! LaughCool
ALD3
Ishtar
Forum Posts: 16
Thanks Received: 6
163
2012/10/23 - 04:51
Uh.. hmm.. it reset itself to default lol... everything's gone. All I did was power it off for a few hours while it charged :\ I'll try to replicate it I guess.
Ishtar
Forum Posts: 16
Thanks Received: 6
164
2012/10/23 - 05:05
Ishtar said
Uh.. hmm.. it reset itself to default lol... everything's gone. All I did was power it off for a few hours while it charged : I'll try to replicate it I guess.
Ok... every single reboot it does a factory reset... help? lol
Any suggestion appreciated at this point. I should add that I did flash CWM from admin's post, if that's at all relevant.
Edit: Think I hit the 0 space left bug. Re-flashed it, so far so good.
Also, CWM cannot do a factory reset, when you click on it, it's like those 3 touchable rows disappear. Back to stock recovery too.
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
165
2012/10/23 - 14:57
Glad you got the factory reset fixed. On CWM, have you tried to reflash it and did you use the install bat or adb. I installed with the install.bat and worked fine, did backup and haven't tried the backup but the size of the files looks correct.
Ok just tried mine, have menu to wipe cashe but like you there is really no menu to wipe......only the warning at the top. You can still do a factory/reset from within settings/backup&restore. I used that before I did the firmware dump, so it works fine.
41 Guest(s)
2 Guest(s)
Devices in use: Desktop (38), Phone (3)
thanhgom2006
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
