Arnova 7 G3 firmware dump (restore your device to stock)
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
136
2012/10/17 - 15:48
http://db.tt/SwYoMEx9
Dump of an7g3 build 2012-06-12 nanda - nandd in 1.rar file
Dropbox
If this is too large for download, let me know and will do each individual. Don't think it is as a good rar compression
The following users say thank you to ALD3 for this useful post:
admin, Ishtar
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
137
2012/10/17 - 15:54
Can anyone tell me what the older AN7G3 build is, as I can't get it off my old 1. Grandkid killed it. Lol
ninjaduck
Forum Posts: 54
Thanks Received: 8
138
2012/10/17 - 17:17
Will advise when I get home.
Am curious to try your dump myself.
Work is for losers, I want more free time!
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
139
2012/10/17 - 17:26
Thanks ninjaduck, I'm intrested too. Was suprised by no lines in skype. I couldn't have done it without all your work and your adb commands. I just barely have ability to work adb. Thanks for all your hard work, we have image backups.
Thanks Received: 3169
140
2012/10/17 - 17:40
That's good stuff, thanks to you guys ninjaduck and ALD3.
I have played with a few firmwares lately, I think current one I run is from ninjaduck's dump, I'm having:
Android build: crane_m723gdxan7g3-eng 4.0.3 IML74K 20120409 test-keys
and Linux Kernel: Linux version 3.0.8 (administrator@admin) (gcc version 4.5.1 (Sourcery G++ Lite 2010.09-50) ) #27 PREE
MPT Mon Apr 9 19:34:09 CST 2012
So ALD3 firmware dump should be newer Wink I'll try it later.
As suggested by ninjaduck, feel free to create a new clean new topic with the essential information regarding the 7 G3 firmware, I'll then close this thread.
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
141
2012/10/17 - 19:07
Great. Thought it was April 2012 on my old one. On this new 1, you can set timezone in tablet setting and cam works with skype, no lines. I couldn't have done it without all the info from ninjaduck and you admin. Thank you. Now everyone can have a better tablet. Too bad ARNOVA hasn't helped their customers out.
Enjoy :-) let me know how it works:-)Cool
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
142
2012/10/17 - 19:13
Admin, maybe you should with our info setup a new topic with the newest firmware dump and instructions on adb commands to install firmware and adb commands to do a firmware dump. Also might want to include CWM recovery install with it. All in one spot. What do you Think?ItItCool
143
2012/10/17 - 19:16
I let you guys do it, you have access to the same information as I do Wink
I'll take care of the topic cleanup/pinning if necessary.
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
144
2012/10/17 - 19:32
Ok then admin, think ninjaduck should do it, I will help ninjaduck where ever he needs it. He is the one that did all the work. He was going to try the newest firmware after he gets home. Hopefully he and you will have the same results that I have on this one and make sure my dump is good.Job
ALD3
Florida
Forum Posts: 107
Thanks Received: 18
145
2012/10/19 - 01:38
Anyone try my dump yet? Need to know if it worked ok and if it helped things ,like setting time zone in settings and no lines when using skype. Let me know if my dump was ok.Confused
146
2012/10/19 - 09:06
I did try it and it works fine, the only problem I found is camera application crashing, I remember some users posted a similar issue when restoring previous dump. I'm not yet sure how to fix it.
I'll do more extensive tests later.
Thanks again for the dump Wink
ALD3
ninjaduck
Forum Posts: 54
Thanks Received: 8
147
2012/10/20 - 21:53
I will be working on tutorial and some other stuff this weekend.  Downloading ALD3's firmware to try it out now.  Sounds like fun.
Ishtar
Forum Posts: 16
Thanks Received: 6
148
2012/10/21 - 01:00
After "cat /mnt/extsd/nandd.img  > /dev/block/nandd", I can't sync.. it says command not found. If I try to cat nandd... again, I get a segfault. adb reboot errors out as well. Then of course reboot never works and all I get is an "Androva" logo, never boots up. Any idea?
Edit: Did it again, segfaulted again but now it boots o.O
Edit again: Used ALD3's dump and it worked first time.
The following users say thank you to Ishtar for this useful post:
ALD3
ninjaduck
Forum Posts: 54
Thanks Received: 8
149
2012/10/21 - 03:06
It shouldn't work. When you write over nandd, you've written over where all the shell commands are stored... it no longer knows how to locate 'sync' until you send it a reboot command. Btw typing with the stock keyboard ubersucks
ninjaduck
Forum Posts: 54
Thanks Received: 8
150
2012/10/21 - 03:37
ALD3 can you advise steps to get superuser working again on your firmware? App installs from play store but will not manage su requests.... everything bypasses it.
85 Guest(s)
Devices in use: Desktop (78), Phone (7)
atgyuric
BBonch
crispyduck00
asgard2701
Rob_nl
shadowlabs
Topics: 6028
Members: 261274
