Not charging please help!
a_elizondo
Forum Posts: 22
2012/07/10 - 09:28
Since I flashed the Hyundai firmware on this forum
http://www.flashmyandroid.com/forum/showthread.php?415-ROM-Hyundai-A7-Firmware-ICS-4-0-3-20120405-Elvish-0-3
I cannot seem to charge my tablet, is this the incorrect firmware? Everything else works great but I can't charge.
a_elizondo
Forum Posts: 22
2012/07/11 - 06:18
Turns out the only way it actually charges is if I press the charging cable really hard in, so it must be a hardware contact issue. I am going to try to return it and see if they give me another one. Unfortunately I have the hyundai rom on it and that might cause issues when returning.... any ideas?
Perhaps I can change the boot screen to look like the original, at lest the part that says Hyundai 🙂
thanks in advance.
Thanks Received: 264
2012/07/11 - 14:03
admin shoul have a back up of the stock rom.
Thanks Received: 3169
2012/07/11 - 14:55
I have partly dumped it, but I'm missing pieces and I haven't yet figured how to complete the dump and reassemble it as a single image. I have read some docs about A10 kitchen and other tools, I just haven't had time to fully check that.
I should give it another look after the week-end, I hope other 7 G3 users can figure it before then Wink
142 Guest(s)
Devices in use: Desktop (128), Phone (14)
neeldes123
yoyo33
doc747
DiVaK
dominik539
DarkWesc
Topics: 6010
Members: 260651
