2012/02/03
ALD3 said
I have just measured the Arnova 7 G3 internal storage speed with Arctools and I'm getting rather fast numbers: Read ~ 19 Mb/s, Write ~ 9 Mb/s ... so there's probably some speed benefit moving the apps on the sdcard if it's a class 6 or faster.
There's probably an impact of the filesystem on the sdcard as well, not sure how FAT32 compares with ext3...
Thanks for the information on speed, I'm running a class 4 32gb micro sd and I knew that the apks seemed faster. Good to know.
Lohtse are you good now? Was out shopping, I have both vold files as I was afraid I might screw up. Saved them bow on my 2.12gb extsd 🙂
hi ald
yep got it sorted thanks to admin...
what am not sure about is why my backed up file didn't work!!!! I always back up the files I mod to restore via androidcommander if needed but when I restored it it still wouldn't work....The one uploaded by admin worked perfectly
now to try and mod the files again and see what happeds....
thank you to both of you for support and responses..
regards
Lohtse
2012/06/12
The following users say thank you to ALD3 for this useful post:
GruberCurrent devices.....Nabi 2, Nexus 7 32G, Galaxy Tab 10.1, Galaxy Tab 7+, Galaxy S2 Skyrocket AT&T 4G, Galaxy 8.9 AT&T 4G
2012/06/12
GMA said
You guys have just made turn in my geek card lol. I just downloaded ES Explorer but I'm not quite sure where to set the R/W permissions and what folder to find the first file. Sorry for all the questionsÂ
Did you get ES set? Go to setting and check UP TO ROOT, then down father check ROOT EXPLORER. Wait for it to get superuser permission and then check MOUNT FILE SYSTEM. That's All
2012/06/12
Dolby said
Will this work also on the Arnova 7D 4GB? Please let me know?
It should work fine as I saw this for an entirely different device and adapted it to An7g3. I would download the original vold file that admin posted and the altered vold that I posted. Compare the original to your vold file, see if they are pretty much the same. If you upload a copy of your vold file, I will take a look. Just be sure to make it clear that it is the 7D 4GB. If you do change your vold file, MAKE SURE TO SAVE a copy before changing it. I would save it is on internal sd, in case your device won't boot. Then you should be able to replace the altered vold with something like Android Commander, should you have a problem. If all works fine, then save a copymof the altered vold also as just replacing with original and reboot will have you back stock.
2012/07/31
 I tried this within ES file explorer. But after waiting i get an error "Test failt your system doesn't support it"
What can i do now?
2x Archos Arnova 7D G3 tablets for my 2 sons.
But i have problems to get microsd working on de arnova 7D G3. Help please!
2012/06/12
What can i do now?
Have you installed superuser and busy box from the Google Play market? If not ,that's your problem. ES file explorer looks for them when you check Root Explorer. Also must give permission to Allow when superuser asks.
2012/06/12
Dolby said
I don't have on the moment google play on my Arnova 7D G3. Only applib.
I would check the Arnova 7D G3 forum to see if they have a Google play setup. If not you might be able to get ours to work. You will need superuser and busybox installed to get R/W permission in Root. Another way is if you or someone has another android device with superuser and busybox installed you can use something like Supermanager to save apk and then email to your Google email, can install both from email. You must go in to settings/security and check UNKNOWN SOURCES, on your tablet before you can install apks that way. Hope this helps.
2012/07/31
 Thanx for the information. I have already turn off the unknown sources. But with applib market there's no
Superuser and busybox. Can i download those apps by PC trough the internet en copy it to the microsd to install it?
Or isn't that possible.
2012/06/12
Sent you a PM check it. I didn't ask you one big question. Is your tablet Rooted? The AN 7 G3 is right out of the box. Superuser and Busybox will not work with out root....neither will ES File Explorer
2012/06/12
debkol35 said
I have a question... If I change external micro SD to Internal SD, then will the tab recognize the internal SD as External Micro SD?
<br
If you change or just copy the altered .vold file posted in this thread then device will read micro ad sd card for internal and your internal 2gig will be your external sd card. That is the reason for changing, my AN7G3 now has an internal sd card of 32 gig and external sd card of 2 gig. Check this entire thread and download the original and altered VOLD FILE POSTED then all you have to do is copy and paste to change.
69 Guest(s)
Devices in use: Desktop (64), Phone (5)
jacksonrid
usdown
ibob64
kawi
vetBro
