How do you flash stock rom?
a_elizondo
Forum Posts: 22
2012/07/09 - 11:14
So I downloaded the stock rom for the Arnova 7 G3 which is Arnova ChildPad (I hope it's the same firmware) I accidentaly screwed it up while trying to install google market and now when I reboot the box it wont let me pass the google setup due to some error. I want to reflash it but have no idea how to.
I have downloaded the update.img file but how do you flash it, how do I enter recovery mode? What application do I use to flash it is it livesuite like the allwinner a10 tablets or is it the rockchip batch tool?
The rockchip batch tool will not recognize my device in what I think is recovery mode (I turned it off and then pressed the mic and power button at the same time and the PC makes a sound saying its alive) but the rockchip tool says no device is connected.
Please help, I will try to contribute to the group as soon as I am up to speed.
thanks!
Thanks Received: 3169
2012/07/09 - 11:24
The Arnova 7 G3 firmware has nothing to do with the ChildPad, they are totally different machine architecture.
We currently have no 7 G3 available for flashing, but the Hyundai A7 tablet which is compatible, you should find the details in our Arnova 7 G3 forum. Flashing the 7 G3 is done thru Livesuite software, Rockchip batch tool won't work on this machine.
a_elizondo
Forum Posts: 22
2012/07/09 - 11:31
Awesome, thanks for the info, doing it right now you rock!
a_elizondo
Forum Posts: 22
2012/07/10 - 01:15
Admin just wanted to personally thank you, works great and now my adhoc network connects with the Hyundai A7 rom
thanks again
Currently Online: -wall-
80 Guest(s)
Devices in use: Desktop (71), Phone (10)
Zanders78
allanchu
konstantin0ss
nikoscc77
hacktes
Walldos
Topics: 6010
Members: 260643
