Elvish ROM
tayab
2013/06/30 - 04:56
Can anyone explain me what is Elvish?? Livesuite?? Adb?? Hyundai A7 ?? etcc.......i dont understand all these?/ n what are they work in tablet????
Thanks Received: 268
2013/06/30 - 12:07
Elvish is a piece of software that makes the link between an allwiner tablet and computer, and it helps flashing/recovering a tablet.
Hyunday A7 is an identical tablet with the 7G3
tayab
2013/07/01 - 03:38
where can i find the elvish piece and how its look like??
2013/07/03 - 11:07
You should find many information in this topic, check last pages for Elvish firmware download link:
http://www.arctablet.com/blog/forum/arnova-7-g3/original-firmware-dump-anyone/
tayab
2013/07/04 - 03:13
thnxx for the reply.... but when i download the elvish file in micro sd card it doesnt work ...because my tablet 7g3 is stuck on arnova screen... how its work on that plzzz explain it to mee thnxxx
lanark
Forum Posts: 13
2013/07/04 - 04:55
@tayab, read the thread from the beginning, please. All the process is crystal clear.
Detection
Forum Posts: 22
Thanks Received: 5
2013/07/04 - 13:54
For future viewers who need the whole process in laymens terms(my apologies if this seems redundant)
1. Download Livesync v1.07 and Elvish 0.3 image
2. Download SDK tools and google how to set up ADB – this is as simple as installing and letting SDK manager install adb platform.
3. Download the firmware dump provided in this thread. You will only need nanda.img, nandb.img, nandc.img and nandd.img
4. Install Livesync and SDK tools and set up ADB.
5. FORMAT a MicroSD Card just to be safe. Make sure it has more than 8Gb
6. Run Livesync, Connect your device and put your device in Restore mode.
- For those who don't know how to do this, Press and Hold reset button (found inside the Mic opening) and Press and Hold Power Button
7. Your Windows System will search for the drivers. Manually search for them in your Livesync Folder under USBDrivers.
8. Select NO on livesync prompt and exit.  Switch off your device completely after drivers have installed. It could be a good idea to reboot your pc too just to be on the safe side.
9. Run Livesync again and open Elvish 0.3 image by selecting the Box icon on the upper left and browsing to the saved dir.
10. Connect your device again and Put in Restore mode again.
11. The image should now start the flashing process. Just select yes on all Livesyncs prompts. Once finished an exclamation prompt will pop up. select ok and disconnect your device.
You now have a working device with Elvish!!!
       …but who wants that right?
12. Start up everything on your device. Ignore all the settings for now.
13. Use your filemanager to double check directories for mounting
14. Copy the nan files to your MicroSD card and put it into your device.
15. open command prompt in windows.
16. Connect your device to your pc and set dubugging on in Developer Settings on your device.
17. In command prompt go to your adb directory and type this:
    – adb device
this should show if your device is visible
then type:
adb remount
adb shell
You now have your devices terminal open in prompt
Now starts the fun part.
18. type:
cat /mnt/extsd/nanda.img > /dev/block/nanda
cat /mnt/extsd/nandb.img > /dev/block/nandb
cat /mnt/extsd/nandc.img  > /dev/block/nandc
cat /mnt/extsd/nandd.img  > /dev/block/nandd
(sometimes this takes a while for the prompt to register but wait until your # shows up before entering each command)
19. type:
sync
20. hold:
CTRL+C
21. type:
adb reboot
Your device should reboot and you should see your ARNOVA logo show up.
this should be enough but as a general rule of thumb, If you see any aps that you recognise from Elvish, go to Settings and do a Factory Restore.
http://www.arctablet.com/blog/forum/arnova-7-g3/original-firmware-dump-anyone/page-7/#p12702
The following users say thank you to Detection for this useful post:
2013/07/04 - 14:18
Thanks Detection for taking the time to do this guide, really helpful.
Detection
Forum Posts: 22
Thanks Received: 5
2013/07/04 - 14:49
Actually credit to "HexagonDigital"
I used his guide to fix my Dads tablet the other day, so found it again and copied it here for "tayab" :)
tayab
2013/08/25 - 07:19
thank u sooooo much Detection for the reply i read the whole thing n i tried but when i connect my arnova 7g3 to computer it says device wont recognize....... now what can i do where can i find the device any idea????????Cry
Detection
Forum Posts: 22
Thanks Received: 5
2013/08/27 - 13:21
Try a different USB lead or a different PC ?
tayab
2013/09/02 - 19:12
i did every possible thing but still it say usb device wont recognize...any other way..???
53 Guest(s)
Devices in use: Desktop (45), Phone (8)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
