corrupt folder or is it?(android.secure)
lohtse
Forum Posts: 157
2012/09/22 - 13:33
Right here's an issue to get your heads around
On my 7G3 I move a lot of apps to sd... Which is great and works perfectly.. BUT if the tablet is rebooted the tablet goes it to a  sort of bootloop(OS loads up completely all apps load etc then reboots) till I remove the card. only way to resolve is to delete the mentioned folder... now as far as I can tell the folder is not corrupt an there seems nothing wrong with is..Logcat doesn't seem to show anything either. Have tried 4 different sd cards and still no joy and it happens whether there are 300 apps or 1 moved to sdcard...Only mod have applied to tab is the one that allows the Physical SD card to be an sdcard not extsd...So whats going happening??
Also anyone managed to use ext2/3/4 partitions if so what app did you use?
regards
lohtse
122 Guest(s)
Devices in use: Desktop (114), Phone (8)
zerpur
Billibon
Enemy777
Duceman
mifeel
maxs
Topics: 6010
Members: 260660
