Corrupt folder issue!
lohtse
Forum Posts: 157
2012/08/03 - 10:53
Right here's an odd issue for you to digest..
If the 7G3 reboots or I reboot it the .android_secure folder corrupts!!!!
And this happens no matter how many apps are in it... So whether its 3 apps in the folder or 217(as I have normal) after a reboot it corrupts and force the tablet to reboot as SOON as it finishes reload the apps drawer(inc apps from the mentioned folder)... As long as I don't reboot or the tablet doesn't randomly reboot all's well it only occurs as a result of a reboot..
So folks any ideas as to why and how to solve it?
I should point out I am assuming it corrupts the folder as after deleting it via laptop it reboots fine and can reinstall apps without issue.
regards
Lohtse
Dolby
Forum Posts: 64
2012/08/03 - 20:08
I think the reason this happens becourse you delete it trough your pc. I think you shout only uninstall the apps by the
Arnova Tablet itself. The register keys and links wil thene nice uninstalled.
2x Archos Arnova 7D G3 tablets for my 2 sons.
But i have problems to get microsd working on de arnova 7D G3. Help please!
lohtse
Forum Posts: 157
2012/08/03 - 21:39
You should read the post as I indicate that the only way to resolve the reboots after app drawer has loaded all apps is to delete the folder via a laptop(or pc) at this point there are nolonger issues ad can reinstall apps.
Dolby
Forum Posts: 64
2012/08/03 - 21:42
sorry my fail. I read the post not good. Sorry for that.
Currently Online: gain9821
93 Guest(s)
Devices in use: Desktop (85), Phone (7), Tablet (2)
aquila73
mansour
napkiraly
ahmedsaad
tiagoz
celinedeuxsevres
Topics: 6015
Members: 260842
