Can I use USB Flash Drive? and 3g Dongle in it?
debkol35
Forum Posts: 44
2012/08/21 - 19:25
I have purchase it today. I have a question:--
If yes..how? There is only one micro usb port.
lohtse
Forum Posts: 157
2012/08/22 - 17:11
firstly you need a micro usn adpter/otg cable they are on ebay for as little as 79p inc free postage... once you have this you need a rootexplorable filemanager such as root explorer or file expert... then sim0ply navigate to root folder and the mnt/ folder and you can explore to usb drive...
as to 3g donlge same adpter but you will have to find a dongle that will work!!! I have a hauwei e160 which works after inputting correct APN settings...
hope that helps
debkol35
Forum Posts: 44
2012/08/23 - 07:48
thanks you sir for your reply. I purchased micro usn adpter and now flash drive is working fine. as far as 3g donlge is concerned, I failed to find the hauwei e160 in the local market. Is there any way to see which donlge will work?
Thanks Received: 3169
2012/08/23 - 09:14
The Archos 3G Stick is compatible, as recommended by the manufacturer:
http://arnovatech.com/products/g3/arn_7/index.html?country=gb&lang=en&p=4
It should be easy to find on line shops.
debkol35
Forum Posts: 44
2012/08/23 - 12:58
unable to find Archos 3G Stick in ebay. I am living in India and here most website dont ship !!
2012/08/23 - 15:11
There is a configuration file in /etc/3g_dongle.cfg on the Arnova 7 G3, it lists and has some configuration bits for the following devices: Huawei E1750, E353, EC1261.
There is chance that means they are supported, but I can't say for sure.
debkol35
Forum Posts: 44
2012/08/23 - 18:57
thank you sir for the info.
I have a question.... is it possible to upgrade android version of this model??
87 Guest(s)
Devices in use: Desktop (83), Phone (4)
atgyuric
BBonch
crispyduck00
asgard2701
Rob_nl
shadowlabs
Topics: 6028
Members: 261274
