Arnova 7 G3 keeps Restarting
Detection
Forum Posts: 22
Thanks Received: 5
2013/01/15 - 23:46
Hey everyone, I bought my Dad the Archos Arnova 7 G3 for Christmas and up until recently it has been great
Lately however he is saying that very regularly it is restarting for no reason quite a few times a day, he says mainly when he touches the screen but not exclusively, it will do it without any interaction at all too
Things he has tried so far,
1. Factory Reset
2. Factory Reset and install apps slowly one at a time until it happens again (In case its an app issue)
3. (Currently Testing) Factory reset and install no apps
The only app he installed after reset number 2 was SwiftKey3, so this time (Reset 3) he has installed no apps at all and is waiting to see if it happens again
I am not new to Android, tablets, and rebooting issues, I have the ASUS Transformer and suffered almost 6 months of Random Reboots and Sleep of Deaths before I gave up on ASUS Stock ROMs and flashed a Custom ROM from XDA, which thankfully cured all my problems
I have hunted around and can't find much in the way of Custom ROMs for the G3 apart from the JellyBean in-progress ROM mentioned on this forum
Also I have checked the Arnova website for stock firmware updates but it seems they have downloads for every tablet except the Arnova 7 G3!
So while trying to support my Dad via email, I`m looking for a little support myself as to what I can advise him to do if this keeps happening, I understand extremely well how frustrating the rebooting bug is after my ordeal last year so any tips or pointers would be very much appreciated :)
I have a far bit of experience flashing ROMs and CWM Recovery etc, a small amount of adb command know-how etc so if there is a workaround that uses those methods that would be fine
Thanks guys :)
2013/01/15 - 23:50
Can you check your kernel & firmware dates, see in Settings / About tablet.
If the newest firmware dump from this thread is more recent than your system it may help giving it a try.
Detection
Detection
Forum Posts: 22
Thanks Received: 5
2013/01/15 - 23:53
Thanks for the quick reply Admin, I've just emailed him asking for those dates, hopefully will get a reply soon
Is there an easy way to flash the firmware dump  that I could explain via email ?
EDIT - Looks like he gone to bed so I`ll update this thread tomorrow with the dates
From a search, it looks like I need to use ADB to flash the firmware dump in that thread?
Thanks Received: 268
2013/01/16 - 00:33
yes, you need adb
post your build detailes and dates from settings/about tablet
i will post the detailes from the dump in 5-10 minutes
Detection
Forum Posts: 22
Thanks Received: 5
2013/01/16 - 00:37
globula_neagra said
yes, you need adb
Thanks, I`ll have to get the dates tomorrow as I don't live with him and he has gone to bed now
I`ll reply when I get them :)
2013/01/16 - 01:39
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=IML74K
ro.build.display.id=crane_m723gdxan7g3-eng 4.0.3 IML74K 20120612 test-keys
ro.build.version.incremental=20120612
ro.build.version.sdk=15
ro.build.version.codename=REL
ro.build.version.release=4.0.3
ro.build.date=2012? 06? 12? ??? 18:57:21 CST
ro.build.date.utc=1339498641
ro.build.type=eng
ro.build.user=administrator
ro.build.host=admin
ro.build.tags=release-keys
ro.product.model=AN7G3
ro.product.brand=softwinners
ro.product.name=crane_m723gdxan7g3
ro.product.device=crane-m723gdxan7g3
ro.product.board=crane
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=unknown
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=
ro.board.platform=exDroid
# ro.build.product is obsolete; use ro.product.device
ro.build.product=crane-m723gdxan7g3
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=crane_m723gdxan7g3-eng 4.0.3 IML74K 20120612 test-keys
ro.build.fingerprint=softwinners/crane_m723gdxan7g3/crane-m723gdxan7g3:4.0.3/IML74K/20120612:eng/opinions-on-teclast-p90hdst-keys
ro.build.characteristics=tablet
# end build properties
ro.product.firmware=1.0
Detection
Forum Posts: 22
Thanks Received: 5
2013/01/16 - 20:05
Ok, he says the only info he can see is this
Kernel version only shows 3.0.8 and underneath says administrator@administration #27
Baseband version 1.0 and Android 4.0.3
He also says since removing the MicroSD Card, it has not crashed or rebooted which also plays in line with the same fix we had for the ASUS Transformer rebooting issues
2013/01/16 - 20:23
maybe the sd card that is used has an issue.
Detection
Detection
Forum Posts: 22
Thanks Received: 5
2013/01/16 - 20:25
Possible yea, although when it was my model tablet with the same issue, it was happening to a massive number of people on XDA so I think its an ICS vs MicroSD problem
Would be interested to hear anyone with the same tablet using a MicroSD without problems, and the make and model card used though
73 Guest(s)
Devices in use: Desktop (66), Phone (7)
relaytester
revoltown
tdomnic024
otismaibe
Tsuna77
