AN7G3 usb cable problem...
606613
2013/05/01 - 15:33
Hi all...
I have problem with charging my an7g3... I have many USB-microUSB cables but they dont charging the device, only keeping it ON. Battery seems to be charging but its not. 6 month ago i purchased usb cable from samsung phone and everything was fine. But now it started againg.
1) Cable works fine with data transfers from PC. (Also flashing ROM)
2) When tablet is turned off its charging normally.
3) When its turned ON its not charging, only keeping it on until 0%. And battery goes down very slowly.
4) Sometimes when brightness is low and not using internet or wathing videos battery level goes up but very slowly. Feeling like not enough energy.
5) At very low brightness screen is blinking.
Is there eny different between USB cables for data transfer and charging USB cables???
I tried 5 cables but all same... The last one (from samsung phones) was working 6 month. Now its like other cables...
I hope someone will understand my English :)
606613
2013/05/01 - 15:46
Now i'm downloading movies ... tablet is connected to the PC and i turned on screen and it starts charging again...
So i must turn off screen or shutdown device for charging...
Thanks Received: 264
2013/05/01 - 15:53
Try to use an usb mini charger that delivers at least 5V with 1A
The usb ports from the pc deliver only 0.5 Amp and it may not be enough to charge the tablet.
606613
2013/05/01 - 16:05
Allready tried... I have factory charger of an7g3, result is same.
I think its not charger problem. Its cable i hope.
Whith samsung phone cable everything was fine . Tablet was charging both from own factory charger and from PC usb port...
But now thomething goes wrong and its like othe usb cables...
I bought 3 cables but all same... works for data transfers but does not charging, or charging but very slowly.
606613
2013/05/01 - 16:06
Ooo... Forgot.
THANK U VERY VERY MUCH FOR REPLY :)
ke4en
2013/05/14 - 05:18
I have the same problem with my AN7g3, but after fooling with it I lost the firmwaree so now it will not run, just gives me some error. What was the outcome with yours?. Did you get the charge problem repaired? Also how can I flash the rom?
thanks, reh.
reeh@copper.net
87 Guest(s)
Devices in use: Desktop (64), Phone (23)
Kaka88
Donalbert
halum
BlackCero044
BlackCero04
taylordahmer
