Accelerometer on this firmware
a_elizondo
Forum Posts: 22
2012/07/14 - 08:39
I believe this has been posted but I can't find it, I want to make sure that the accelerometer does not indeed work after flashing the elvish 0.3 firmware is this correct?
a_elizondo
Forum Posts: 22
2012/07/14 - 09:18
oh by the way, I did notice the original firmware had acceleration working, perhaps we can pull the drivers and build.prop to see what are the differences and if we can get it working on the elvish rom?
SRH990
Forum Posts: 13
2012/07/14 - 17:52
Yes, you are correct, the accelerometer doesn't work on the elvish firmware or the Hyundai A7 original firmware the elvish version is based on.
a_elizondo
Forum Posts: 22
2012/07/14 - 21:34
I might be able to create a fix, but I need these files from the original firmware (SYSTEM folder) can someone please upload them?
├───bin
│ sensorservice
├───etc
│ └───firmware
│ dsps_fluid.b00
│ dsps_fluid.b01
│ dsps_fluid.b02
│ dsps_fluid.b03
│ dsps_fluid.mdt
└───lib
│ libakm.so
│ libsensorservice.so
└───hw
| sensors.default.so
Thanks Received: 3169
2012/07/14 - 21:42
I'm preparing a full dump of the Arnova 7 G3 system partition for lohtse, I'll send the link to you as well, so you can get all the files you need Wink
a_elizondo
Forum Posts: 22
2012/07/14 - 22:12
awesome thanks!
a_elizondo
Forum Posts: 22
2012/07/15 - 19:13
Still working on the script, the last few attempts were no go, I will upload as soon as I get it working.
Thanks to Admin for giving me a copy of the system folder to play with!
a_elizondo
Forum Posts: 22
2012/07/18 - 08:27
It is sadly a no go, I have tried hundreds of versions of what I have made with no success.
Hoping on some other future firmware which will have accelerometer fixed...
606613
2012/11/11 - 17:18
Is there any way to calibrate or to set accelerometer's parameters to default???
My accelerometer work fine with screen rotate, but in racing games it pulls (goes) to the whrite a little. I must to hold tab some inclined to go straight.
tab: an7g3 run ice cream sandvich 4.0 (stock)
approximately in this position car or bike goes straight...
P.S. it was very difficult to express my problem in ENGLISH :) I hope U will understand my confused reply...
79 Guest(s)
Devices in use: Desktop (68), Phone (9), Tablet (2)
ycdrwho
ESPADA
Fjustino
Lexibook333
honkomat
lex42
Topics: 6015
Members: 260828
