Tablet frozen after restart, Firmware Updating message
sekretar
2012/06/02 - 09:34
Hi guys
I have strange problem with Aronova 7 G2.
Suddenly I got message "Firmware updating"
And I have Install and Cancel buttons, but touchscreen is frozen. This happens even after reboot, I see Calibration message and that this black screen appears and ... nothing. Can someone help me with this?
Thanks Received: 3169
2012/06/02 - 09:37
Try putting a paperclip in the reset pinhole button, if that does not help, you're probably good to flash a firmware.
Use Rockchip flashing tool with the current custom firmware if you used one or with the stock firmware from the vendor:
http://www.arctablet.com/blog/featured/arnova-firmwares-updates/
sekretar
2012/06/02 - 09:40
After hard reset (from pinhole) it happens again. I will try with tool you suggested.
thnx
sekretar
2012/06/02 - 10:13
buh.... I can't get this device to recovery mode.
I turn device ON,
An than I "put the Power switch to the right position (when a little lock is drown)"
  After that
insert a paperclip in the Reset pinhole on the back of the tablet.
But, device just turns off
2012/06/02 - 10:22
Well, the screen should get black (turned off) but the device is still on. If you run Rockchip Batch tool, install the drivers and see the green square you should be good to flash. If it doesn't work, please check the troubleshooting section on the flashing page.
sekretar
2012/06/02 - 10:26
Oh, 🙂  it runs now, thank you. I was waiting for some "restore mode" message 🙂
sekretar
2012/06/02 - 10:37
This is OK, thanks a lot.
I wonder now, was it better that I installed different firmware? My son use this tablet just for games. Any suggestion about that?
2012/06/02 - 10:41
A custom firmware will give you Google Play / Android Market support and sometimes extra features or small system speed improvements. A good one is Fenice57 firmware that you can find here: http://www.arctablet.com/blog/featured/arnova-7-g2-firmware-root-market-3g-ntfs-bluetooth-cifs/
If you/your son are happy with the default firmware from the manufacturer you can probably stick to it 😉
sekretar
2012/06/02 - 16:31
I am confused, because I don't have applib, and don't know how to install software. Any trick?
///edit
appslib downloaded.
Thanks a lot, saved my tablet 🙂
Currently Online: nikoscc77
137 Guest(s)
Devices in use: Desktop (124), Phone (14)
nikoscc77
hacktes
Walldos
MOUNIR 1923
cynthiavd
rafi462
Topics: 6010
Members: 260640
