It is exemplified very well here how you should enter in flashing mode
if your tablet is in a woking condition you an alo use
adb, with the command
adb reboot bootloader
or a terminal app with the command
reboot bootloader
all the above will get you tablet in flashing mode.
Rockchip Batch Tool should be able to update from any firmware, even a damaged one or non booting tablet.
cjs302turtle said
I tried the rockchip tool and that did recognize my device either... im asking do i also have to be on stock firmware???
Try to install the drivers first and after that use the rockchip tool.
2013/05/15
the drivers on the batch tool do not work all it says is windows has recognized the file to be installed or something? im at a complete loss here. the firmware im on now is the stock stuff I have flashed from arctools already and when I try to put it in flash mode with the reset button and the lock on all it does it pull up an unknown device notification and does nothing and I can not do anything with it... my
htc wasn't this hard!!!
73 Guest(s)
Devices in use: Desktop (60), Phone (12), Tablet (1)
lokeshreddymtpl
scoopsat
Mikewood
XSTR
aldi_2003
dtcinfly
