need help please
d-man
2012/06/04 - 11:13
hi all ;
i am new here and i have arnova 7 g2 so i want an easy way to root it,
and if you can i need a good ics rom without problem in wirless ram.........
thank you every buddy
Thanks Received: 3169
2012/06/04 - 11:27
This Arnova 7 G2 firmware from fenice57 is probably worth trying.
Vrailink
Forum Posts: 45
Thanks Received: 6
2012/06/04 - 13:41
Hey I also have the arnova 7 G2 and I tried almost every rom available for my device. The best one so far is finless rom 1.5. You can find it here: http://www.freaktab.com/showthread.php?618-Arnova-7G2-Finless-1-5-Beta-Test-ROM
It is still 2.3 as there are no working ics roms at the moment Wink
Bob is working on a 2.3 rom with honeycomb looks. a bit like the morkamod but with better stability,... Smile
Hope this helps and good luck Laugh
79 Guest(s)
Devices in use: Desktop (73), Phone (6)
atgyuric
BBonch
crispyduck00
asgard2701
Rob_nl
shadowlabs
Topics: 6028
Members: 261274
