My device is rooted but i can not excess system
danckm
2012/07/23 - 19:14
Hello everyone.
My device is arnova 7 g2.now i am using "Arctablet Kitchen – Build your custom Arnova firmware "
I can open system folder but i can not copy,move,rename or paste something in it even i mounted RW.
Something i need to paste to system is some fonts that support reading document with my language
Every help is appreciative!
Thank everyone.
ps: sorry because of my english
Thanks Received: 3169
2012/07/23 - 19:18
The custom firmware built by our kitchen keeps the default CRAMFS for /system, which is read only, it's cannot be remounted as r/w. An option is to use fenice57 Arnova 7 G2 firmware which should have /system using ext4 filesystem that is mounted r/w.
In the future, we also plan to offer custom firmwares in the kitchen with writable /system in ext3 or ext4.
danckm
2012/07/23 - 20:02
Thank Admin!
I tried fenice57's firmware and i had some problem that i did't know how to solve.For example. error wifi , can not open needed root apps.i dont know why.maby the reason is some fonts i put on system?
And about CRAMFS,ext3,ext4 . I see that MorkaMod's firmware support all this. I tried version 1.15 and i have error superuser denied everthing.Then i think to version 1.14 . but this version is support CRAMFS,ext3,ext4 . i dont know choose which? Can you tell my which i should choose?
Thank you.
Sorry because of my English
2012/07/23 - 20:09
As I mentioned, ext3 should give you r/w access; ext4 is an updated version which provides a little speed improvement.
I don't think Morka made an ext4 version of his firmware, you should choose an ext3 version if you want r/w /system but I don't think ext3 versions were made for  all his updates; he hasn't made any new version in months anyway.
danckm
2012/07/23 - 20:19
Thank you , Admin.
I got it.
Wish you all the best!
74 Guest(s)
Devices in use: Desktop (70), Phone (4)
atgyuric
BBonch
crispyduck00
asgard2701
Rob_nl
shadowlabs
Topics: 6028
Members: 261274
