ICS 4.0.3 Porting ROM for ARNOVA 7G2
kobol
Portugal
2012/04/06 - 01:42
Just testing and waiting for the preview of the rom i promise you we will have a ics 4.0.3 rom soon for Arnova G2 series...
Just testing now and only with otg cable mouse and no audio no wifi but have camera.
Thanks Received: 264
2012/04/06 - 01:47
can you share your method to port the drivers ?
kobol
Portugal
2012/04/06 - 01:55
As part of the system they communicate with the libraries to give control to the hardware so if the first rom his same board and processor we will have to try the libraries because most of the drivers are already in the system.
2012/04/06 - 02:02
so, with other words, you will try each library :))
kobol
Portugal
2012/04/06 - 02:14
No the libraries are in sdk so if you want you build for the specific system or you can try export from a funcional system but you have to know wich libraries to export.
kobol
Portugal
2012/04/06 - 02:14
2012/04/06 - 02:27
do you have a source where i can read for what is each library ?
2012/04/08 - 16:45
Look at this specs
• Display :                             7" digital TFT, resolution  800*480(16:9)
• Touchscreen :                    tehnologie capacitiva multi-touch ( 5 points touch)
• CPU :                                 1 Ghz ARM Cortex A8 Rk2918, 512 Kb cache, accelerare 2D/3D, Open GL ES2.0, Open VG, 60m tri/s
• RAM :                                   1 Gb DDR3
• Memorie interna :             8 GB EMMC
• Sistem de operare:           Android 4.0.3 ICS
• Camera :                            0.3 M pixel
• MicroSD :                            pina la 32 GB SDHC
• WiFi :                                   IEEE 802.11b/g/n
• BT :                                      Nu
• 3G :                                      suporta WCDMA 3G extern
• G-sensor                               Da
• USB1 :                                  micro USB 2.0
• USB2 :                                   micro USB 2.0
• HDMI :                                 Nu
• Audio :                                 speaker , 1x audio output ( 3,5mm), 1x MIC
• Baterie :                               4500 mAh la 3.7V
• Audio decoder :                  MP3, WMA, OGG, AAC, FLAC, APE, WAV
• Video decoder :                  AVI, WMV, MP4, MKV, RM, RMVB, FLV, MOV, 3GP, up to 1080P
• Abobe flash :                       Adobe Flash player 11.1
• Aplicatii :                              Android Market, Browser, Calendar, Notes, Google Mail
• Photo :                                 JPEG, BMP, GIF, PNG, JPG
• Ebook :                                ANSI/UNICODE TXT, PDF, PBD, Epub,FB2, HTML
This tablet has ics 4.0.3
InfoTouch iTab 701
kobol
Portugal
2012/04/09 - 00:15
Hi i just made a preview alpha testing rom for arnova g2 tablets with ics 4.0.1 i just try the ics 4.0.3 but with too much fcc and to slow now i will present you a good alpha testing rom for g2 tablets with ics 4.0.1.
That specification don't match i try with a rom from that tablet but with no success.
Ok guys i will send the link for you test the i.c.s 4.0.1 on your tablets but only in a phase alpha test only rom.
Jekle
UK
Forum Posts: 31
2012/04/09 - 20:59
I'll be glad to help (assist) you with this project. So After Messing about with ICS, what working and whats not? (in the 4.0.1 version) Be sure to upload your work Laugh
kobol
Portugal
2012/04/10 - 12:03
Ok Jekle i'm need here some help because is to much work to be done i'm going back for the first post and send the file with a port of ics 4.0.3 from the rom of oma for loox and is too much things there are missing.
Thank you Jekle just pm me when you are online.
ROM_ICS_AN7G2_OMA_LOOX_PORTED_by_Kobol.zip
NOT WORKING WIFI, TOUCH, SOUND, AND MUCH MORE BE SHURE TO USE OTG CABLE TO USE THIS ROM
USE AT YOUR OWN RISK NOT STABLE ONLY TEST
I NEED HELP TO THIS ROM THANK YOU TO ALL FOR YOUR PATIENCE
2012/04/10 - 13:19
I can give you some tips 🙂
You will need to recompile libhardware_legacy.so (in this way you will give the right paths towards the hardware.)
In arnova 7cg2 in the boot.img there are also other files that i changed and the final result was:
Wifi starting but the wpa.suplicant deamon failed to start.
ukbeast
Shrewsbury, UK
Forum Posts: 11
2012/05/11 - 23:44
Wow nice work lads, you will keep ue posted right? 😉
Live life to the fullest, Choose Linux over Windows
AndroidFUN_MD
Forum Posts: 11
2012/05/12 - 13:31
Can you improve your firmware?
I'm waiting for long time ICS on my arnova 7 g2
ukbeast
Shrewsbury, UK
Forum Posts: 11
2012/05/26 - 18:33
Not any news so far,
What changes are made so far?
91 Guest(s)
Devices in use: Desktop (78), Phone (9), Tablet (4)
mansour
napkiraly
ahmedsaad
tiagoz
celinedeuxsevres
15djamal15
Topics: 6015
Members: 260841
