How many firmwares can Arnova 7 g2 be apply?
danckm
2012/07/28 - 17:35
Hello everyone.
I know some firmwares for Arnova 7 g2 that are:
1.Stock fw.
2.Custom firmware built by arctablet kitchen.
3.Fenice57's fw
4.Morkamod's fw
5.Finless's fw
So, maybe there are some firmware that i dont know.Please someone can tell me how many firmwares can Arnova 7 g2 be apply? and what are those?
I used to flash fw from computer by rockchip flashing tools or RKxxxxx.I wonder that i can use apps or tools to install new fw itself on my arnova 7 g2? for examble arctools? rom manager? ....
Thank all.
Thanks Received: 3169
2012/07/28 - 20:33
There is also our custom firmware which is similar to the one from our kitchen, with added Bluetooth support, see here:
http://www.arctablet.com/blog/firmware/google-play-store-android-market-root-bluetooth-gps-arnova-7-g2-capacitive/
Arctools flashing method works with the firmware listed above, for any firmware that comes with an update.img file, you can use Rockchip flasher to send it to the tablet. When testing different firmwares, better use "Restore" button in the tool than "Upgrade" to make sure the tablet is properly erased before flashing.
danckm
2012/07/29 - 02:18
I can add one firmware into list that is Jekle 's .cyanogenmod 7 for arnova.
Here is link:
http://www.arctablet.com/blog/forum/arnova-7-g2/cyanogenmod-7-2-for-arnova-7-g2-beta-1/
Plz check link http://www.arctablet.com/blog/arctablet-kitchen-build-your-custom-arnova-firmware/ I cannot enter  this link.
Thanks again!
jsthegame
2012/08/17 - 11:24
hello. does anyone knows if the firmewire "update.AR7G2.cramfs.2G.MorkaMod.v1.15" has some setting to keep the option bar always on, or something like this? is very hard to go back when I use for exemple the Mxplayer or some games. I've to torn off the arnova, and start all over again.
My second question is, if with this I've the root maked (and I see it by the free space that I've gained it) why the superuser elite edition doesn't allow me to permit some choises that I want and why it keeps running as user and not as administrator?
Thank you for the help on this
danckm
2012/08/17 - 11:41
Hello.
I have some ideas and  hope will help you
1.Use Button Savior or same apps
2.This is problem of this firmware.We can not do anything.But thank to Morka because nice firmware.
89 Guest(s)
Devices in use: Desktop (84), Phone (5)
atgyuric
BBonch
crispyduck00
asgard2701
Rob_nl
shadowlabs
Topics: 6028
Members: 261274
