help usb port on Arnova 7 G2
sidewinder
2012/10/03 - 18:02
hiya new member here . im sorry ,if this is posted in the wrong place . if it is then please can u move it to right place thanks
ok my usb port is broken and the points where the connect goes are to small to solder 5 points . im ok at soldering stuff , just not that small . is there any other points i could use to rewire a usb cable to  even if its just tempory to do the following .  ? . main resson i would like  to sort this is so i can  flash the  new  Android 4.0 ICS cfw for it . or is there another way i could do it . ? at the moment im on Fenice57 cfw
thanks for your time reading this and again im sorry if  this  in the wrong places
Billybluff
Amstelveen
2012/10/12 - 12:30
What u could do is:
Open up your tablet
De-solder the Usb female plug in your tablet to remove it, and permenently wire (solder) a striped end of a mini usb cable onto the deignated pads (with any luck these pads should be double sided with small metal gromets connecting both sides of the pcb)
directly on the pcb.
ps don't forget to make a strain relief in the tablet
104 Guest(s)
Devices in use: Desktop (89), Phone (15)
abdelouahabido
ble1x
darlaive
bogdushok
Torn
zombo
Topics: 6011
Members: 260681
