Help to get root access!
Tags: root
Related Tags
Mrak667
2011/12/05 - 15:57
[Image Can Not Be Found]I can not get root access! share the information how to obtain these rights
Sowa
Russia, Novorossiysk
Forum Posts: 47
Thanks Received: 5
2011/12/05 - 18:40
To create a Custom ROM firmware dump is needed.
If someone has to merge, I do Custom ROM for AN7G2.
How to make a dump can be found here  1-9
China phone: Star A5000 => Star N8000
Tablets: Archos 7C HT - Android 2.2.1 my custom ROM => ARNOVA 8G2 8Gb capactive, s_MorkaMod JB 1.2
deinef83
2011/12/12 - 07:45
I have made dumps of the boot, recovery, system & backup/update if you would like them [Image Can Not Be Found]
Sowa
Forum Posts: 47
Thanks Received: 5
2011/12/12 - 15:55
I already got a dump from one of the forum 4pda.ru. Unfortunately Firmware in the "wrong" ROM (described here). While looking for a workaround.
finless
Stanton, Ca
Forum Posts: 604
2011/12/24 - 17:49
Sowa said
I bet this can be fixed with the boot.img being a messed up cramfs for this device!  The RKAndroid tool that allows you to flash specific images like boot.img may solve this.  In my Arnova 10G2 root firmware kit I provide that tool.  I bet if you took the boot.img from my kit for the Arnova 10G2 (modify init.rc back to mount cramfs /system  e.g. comment out my ext3 mount and uncomment the cramfs mount) you can boot and have a good boot.img to then work with.
If someone is willing to test I can try to make a rom with a good boot.img that is not messed up?
Bob
programmer_94
2011/12/28 - 23:55
finless said
Sowa said
Bob
ok, i will Laugh
84 Guest(s)
Devices in use: Desktop (80), Phone (3), Tablet (1)
dcatalan
dshepp
kaironit
qweku1
himeji
robotx
Topics: 6028
Members: 261291
