Charging [Moved]
useless
2012/08/09 - 22:15
The battery socket connection on my 7G2 has broken and I am now unable to recharge the battery. Is there another way in which I can charge the tablet or is it only fit to throw out?
Any help would be greatly appreciated.
[Moved to Correct Forum]
Thanks Received: 3169
2012/08/13 - 19:27
The Arnova 7 G2 doesn't charge thru USB so using the power socket is the only way. You may get a quote for repair asking Arnova, but it will probably be more expensive that a second hand tablet.
If you know how to solder, you may be able to replace the connector by yourself.
I did it on an Arnova 10 G1 (see here) and mobius forum member here did it on an Arnova 10 G2, see here.
79 Guest(s)
Devices in use: Desktop (75), Phone (4)
atgyuric
BBonch
crispyduck00
asgard2701
Rob_nl
shadowlabs
Topics: 6028
Members: 261274
