Cannot install Viber on Arnova 7 G2 (fenice57 custom firmware)
fyedka
2012/03/21 - 14:31
Hi!
I've installed this rom and I tried to install viber.
market showed that this tablet cant download so I did download from here: http://helpme.viber.com/index.php?/Knowledgebase/Article/View/100/0/cant-download-from-android-market
When I open de .apk with file manager it looks like the app were installing, but after a few seconds a message appear telling "not installed"...
well I tried everything, the last thing was with adb commands and I got a message telling that a library is missing...
looking for an answer I found viber 2.0, and I succesfully installed this version, but it haven't images support and can´t do phone calls trough the net to people who have viber 2.1.
well, I don´t know if anyone could help me finding that misterious missed library.
thanks in advance 🙂
Thanks Received: 3169
2012/03/21 - 14:51
fyedka said
Hi!
thanks in advance 🙂
Just tried to install Viber 2.1, from logcat, you see the reason it doesn't install:
E/PackageManager( 90): Package com.viber.voip requires unavailable shared library com.google.android.maps; failing!
Will have to check in this direction...
fyedka
2012/03/21 - 17:34
thanks! ... I downloaded this version: http://www.mediafire.com/?58112957ex0wsu9 but still not working...
Do you know if there is a way to find out wich librarys, repositories, dependencies viber need to work?
I'm google-ing right know, but every suggestion will be apreciated...
thanks again!!
2012/03/21 - 17:59
I found that:
http://www.callum-macdonald.com/2011/02/06/missing-com-google-android-maps/
Which fixes the problem, well at least Viber installs, I haven't tested further.
The procedure on this web page needs some changes to work on our setup.
You can use Gapps from CM7: http://cmw.22aaf3.com/gapps/gapps-gb-20110828-signed.zip
Then copy that file on the Arnova 7G2: /system/etc/permissions/com.google.android.maps.xml
You'll need to use the command line with adb push/shell or use an application such as Root explorer or another advanced file explorer to access /system.
fyedka
2012/03/21 - 18:41
he he he! thanks a lot!!
muchas muchas gracias 🙂
this works at last 🙂
I found same instructions at xda forum: http://forum.xda-developers.com/showthread.php?t=1434809
edit: and I also read about manifest.xml ... in case that someone want know wich are the missing libraries.
http://developer.android.com/guide/topics/manifest/manifest-intro.html
Currently Online: izemnagh
99 Guest(s)
Devices in use: Desktop (90), Phone (9), Tablet (1)
15djamal15
Mansonforever
painor
izemnagh
evas1on
castel_010
Topics: 6015
Members: 260836
