Arnova 7G2 JB 4.1.1 v1.2 by Oma
AcerExtensa
2013/06/24 - 18:16
Somehow I have got it working... have installed all zip patches and now have WiFi and so on... But I still have troubles with SD cards... they work great under CWM, but I can't get it working in OS.... it always tries to prepare SD card and nothing happens.... I have tried 4 different cars(one 64MB :) from old nokia phone) and can't mount them....
Do you guys have any troubles with SD cards on this tablet?
Vrailink
Forum Posts: 45
Thanks Received: 6
2013/06/24 - 18:47
My sdcard works just fine on the OS but mounting on the pc doesn't work for me. That's the only issue I have :)
DainoManthis
Forum Posts: 23
2013/08/06 - 20:58
I installed it but I have a problem, I can't download from play store an app that I bought and worked with 4.0.3 ics rom..
Is this jellybean not fully rooted?
How can I root it to install every app?
Vrailink
Forum Posts: 45
Thanks Received: 6
2013/08/06 - 23:45
I know that there have been similar reports with other roms. Try clearing all data from the play store app (settings -> apps -> play store -> clear data) and restart the store. This rom is fully rooted. I hope this helps ;)
DainoManthis
Forum Posts: 23
2013/08/08 - 05:01
Thanks for the fast response..
I'll tell you, the most important thing to me (except that the rom is very very fast), is the fix to connect in ad hoc (I have a Nokia Smartphone with Symbian that generates only adhoc access point).
I will try again to clear data and restart the store.
I have another trouble with the rom, but it's not just for this version, I tried 2 versions of 4.0.3 ics by Fenice.
I'm trying to connect the PSP as a gamepad for the tablet using Fusa Gamepad as psp driver (a driver that converts psp in a pc joypad) and USB joystick center on android (an app that reads input devices).
After different combinations I had this results:
Fusa gamepad 0.1 works with usb jc 6.41 but it's very slow (not tablet faults, it is a fusa beta slow on the pc too). This version of fusa doesn't work with every other version of joystick center.
Fusa 0.2 and 0.3 doesn't work with any version of the joystick center. It recognizes the joypad but the byte communication line is almost all flashing dots.
But ps3 joypad works on the Arnova (with joystick center) and psp with fusa 0.2 and 0.3 worked on my friend's tablet (Mediacom smartpad 705i.. with android 4.04, using the same versions of fusa and joystick center)
I think it could be a kernel problem, but not sure, 'cause my friend's tablet is 3.0.8+ kernel too.
DainoManthis
Forum Posts: 23
2013/08/08 - 12:45
I think the problem is that the psp driver pad works on a command line of 8 bytes (it uses 8 bytes in my friend's smartpad mediacom), on my arnova it recognizes 4 bytes with the result of flashing dots in all the line, like it changes always the position bits (I think that the psp use position bits for x/y axes for digital pad and z/rz for right analogic), on correct 8 bytes line they stay separate (dpad takes some bytes fixed, analog pad takes others bytes), in the wrong 4 bytes line they switch always in the same line)
Vrailink
Forum Posts: 45
Thanks Received: 6
2013/08/08 - 14:14
You're welcome :) I hope the store problem is resolved.
I would love to help you but I don't have a psp to test this out so I'm at a loss here. I suggest that, if no one replies here, that you start a new thread in the arnova 7g2 forum. I'm sure you'll get a faster response and a lot more people to help you ;)
Good luck and have fun
DainoManthis
Forum Posts: 23
2013/08/08 - 16:44
Thank you, I'll try this way :)
DainoManthis
Forum Posts: 23
2013/08/08 - 20:09
I tried to clear data but it's the same, I'm unable to find my app with this version of firmware..
Vrailink
Forum Posts: 45
Thanks Received: 6
2013/08/10 - 13:34
Hmm that's strange. What is the name of the app you are trying to download. I'll look if I can find it on the store. Otherwise you'll have to look for an apk of the app and install it from your sd card. This could work too :)
DainoManthis
Forum Posts: 23
2013/08/10 - 19:05
It's a game I bought, King of Fighters Android (by ggee.. there is a fake version by another pubblisher that appears before the right one)
It worked on 4.0.3 ics by Fenice.
Controlling it by play.store on the pc, it says "Some of your devices are supported" it appears ok for Arnova 7g2i (play store recognize 4.0.3 ics as 7g21) and not ok for Arnova 7g2 (play store recognize this 4.1.1 as arnova 7g2 simple and not 7g2i)
This rom is very fast and works very well, but Skype goes slow, it blocks, loose connection very much times in a little time and webcam works 1 time on 8 tries.
DainoManthis
Forum Posts: 23
2013/08/10 - 21:28
Hello, I want to ask you one thing, I think my problem with psp connecting can be solved with a module that missing from the tablet.. it's the joydev.ko.
But I have read that to make it works correctly you have to compile it properly for the device.
Is there a way for you to compile a copy of this module for arnova 7g2?
Vrailink
Forum Posts: 45
Thanks Received: 6
2013/08/10 - 21:33
I tried king of fighters and it appears on my device so I don't know what the problem is there.
I am not the creator of this rom, maybe you can try asking Oma for this ;)
DainoManthis
Forum Posts: 23
DainoManthis
Forum Posts: 23
2013/08/10 - 22:37
The first I linked is a fake, the original is the second (the one I bought, the fake is free)
118 Guest(s)
Devices in use: Desktop (113), Phone (5)
