Arnova 7G2 firmware 2011.12.13 update available
Thanks Received: 3169
2012/01/05 - 21:08
Arnova has released a long awaited firmware update to their Arnova 7G2 device. The changelog confirm Archos 3G Stick support, compatibility with Adobe Flash 11.1 and few minor bugs fix without much details. Let's hope to see that Arnova will make firmwares available for all their G2 devices soon.
According to the release information, the following changes are expected:
Version 2011.12.13 - December 13rd, 2011
  • Support for ARCHOS G9 3G Stick (via USB host cable)
  • Flash™ 11.1 compatible
  • Minor bugs fixed
Arnova 7G2 Firmware download
update.img
Firmware update procedure at Arnovatech.com
Thanks to our Forum user coltracer for the information.
josbos
Forum Posts: 57
2012/01/05 - 23:30
Finally some release notes. Checked and they're providing it for the other firmwares as well.
finless
Stanton, Ca
Forum Posts: 604
2012/01/06 - 01:24
I am downloading this as we speak.  Hopefully system.img is not hosed up like the one that was uploaded to Megauploads!
if I can mount system.img then I will root this baby!
Bob
finless
Stanton, Ca
Forum Posts: 604
2012/01/06 - 02:24
BINGO!  This rom I was able to unpack and system.img works and I can mount it!
Stay tuned for a ROM for it!  I should get'er done tonight!
However because I cannot test you guys will need to BUT the good news is now with a update.img from Arnova if my ROM doesnt work you can flash back!
Bob
nazull
2012/01/06 - 02:26
ok so i have an AN7b g2, supposedly the only difference between it and the 7 g2, is mine has a resistive touchscreen. so i downloaded the update.img, saved to root, turned off usb storage mode, gives me an error about invalid firmware image, would i like to delete it. anyone have any idea why this might be happening?
alex
Forum Posts: 252
2012/01/06 - 02:33
6ou have to dl the correct firmware for your device however im dont think one hws beenrelised for the 7b g2 ijstalling the fimware for 7 g2 is justbthe same as installing it on the 10g2 it just dosent go
alex
Forum Posts: 252
2012/01/06 - 02:37
And do you mean 7c not 7b ?
nazull
2012/01/06 - 02:49
no, 7b... same as 7 g2 only different screen
nazull
2012/01/06 - 02:52
7c runs qualcomm cpu, 7b g2 runs rockship same as 7 g2
nazull
2012/01/06 - 02:59
check the specs, they're xactly the same, in every way, besides the touch screens
alex
Forum Posts: 252
2012/01/06 - 03:12
Well the fact that they are different in the slightesst way makes the difference if they are this similar then it might only meaan the slightest ajustment to the fw to allowit to run on yours however as there is no official package or rom dump to fall back oni dong suggest doing it
finless
Stanton, Ca
Forum Posts: 604
2012/01/06 - 03:27
Uploading my rooted firmware now.  Stay tuned for the post!
The 7v G2 is a different tablet.  Yes it maybe only the different touch screen but it's ID wont be the same as the 7 G2 and thats why the recovery system is rejecting the update.img!!!
This was the same issue with the 10b G2 abd the 10 G2.  Different kernal drivers for the screen.
You 7c guys DO NOT FLASH MY ROOTED ROM!  You will have a non-working screen forever until Arnova comes out with a update.img for the 7c to reflash.  PERIOD!  A guy with a 10b G2 flashed my 10 G2 firmware and that is exactly waht happened to him.  It booted but the touch screen would not work and he could not get past calibration loop!
Bob
simonkitch
2012/01/06 - 11:14
Hi, I have a Arnova 7 G2 which has Market Gmail etc working. Just wondering if it will still have Market etc after flashing with firmware update from Arnova?
John Doncaster
2012/01/06 - 21:48
As a beginner at this - how can I tell I have installed new firmware? Have I just downloaded it and not installed it? No message on screen.
2012/01/06 - 21:49
You probably have copied the firmware to the wrong place, it should be in the root directory when the drive is mounted on your computer.
Currently Online: inviner
132 Guest(s)
Devices in use: Desktop (108), Phone (21), Tablet (4)
inviner
offcrash
mrbit
LeonDCA
mrscharling
ebbi1978
Topics: 6030
Members: 261556
