Arnova 7G2 battery only updates the level after system reboot
Related Tags
ip
new delhi , india
2012/07/17 - 16:09
Heylo AT forum for arnova 7G2 this is my first post i'm enjoying so far   , i recently got AN7G2 it was after i got a shipped an not so lucky Archos 70 IT 250 hd version so far so good with arnova i do miss the bluetooth fairy on it though .
so
- i have updated the firmware already , its a stock firmware not any changes device is not rooted
The issue that i'm having is the battery level while charging gets stuck some times 23% 24% some time 65% 68% basically its erratic has no method to it , but i know in my head that the battery charging doesn't take that long ( say more than 3 hrs)
so i switch it off and ON again wallah battery 100%
i got the easy reboot it did the trick the first time but then it didn't change the level ,
i diiging is it the battery ? is it the firmware? is it android ? no charger is not the culprit , and i saw this post querry about this issue quite old it was but no remedies so far
please try and help me if you can if you've noticed this bug
thanks
ip
Thanks Received: 3169
2012/07/17 - 16:39
Well, I'm not a frequent 7 G2 user, but I can only say I've noticed the battery information wasn't very reliable on this device and was subject to important variations. Unfortunately, I haven't investigated enough to say if it's a firmware issue or an hardware/component problem.
finless
Stanton, Ca
Forum Posts: 604
2012/07/17 - 20:41
It's a firmware issue.  It can be fixed by editing services.jar.  Dec. update from Arnova broke the battery icon and any information in settings about battery.
Bob
ip
new delhi , india
2012/07/18 - 19:07
Thanks Bob , respect your input on this . if you could please explain the procedure to do that , then this post will become the perfect conclusion to battery level issue . do i need to take any system dump or save certain backup modules , i'm using ubuntu12.4 . my knowledge to modify or edit system(s) is moderate . i'm plugged in waiting for your response , force is very strong with you ,
cheersbeers
ip
http://www.menwhopause.com
ip
ip
new delhi , india
2012/07/22 - 07:37
finless Bob , whenever you have time do post , thanks
ip
106 Guest(s)
Devices in use: Desktop (101), Phone (5)
atgyuric
BBonch
crispyduck00
asgard2701
Rob_nl
shadowlabs
Topics: 6028
Members: 261274
