It looks like Arnova has decided to recycle their old Arnova 7 G2 and update these tablets to Android 4.0 Ice Cream Sandwich (ICS) like they did for the Arnova 9 G2i.
At first look, this model is just an Arnova 7 G2 tablet with the same specs: Rockchip RK2918 CPU at 1 GHz, 512 Mb RAM, 7" screen. This "new" Arnova 7 G2i seems to be currently available in a few European countries (Belgium, Netherlands, UK).
The product box is identical to the old Arnova 7 G2, with just an additional Android 4.0 ICS sticker.
The system is running on Android version 4.0.3 (build eng 4.0.3 IML74K eng.root.20120615.040238 test-keys) with a Linux Kernel version 3.0.8+ (built Fri Jun 15 09:25:37 CST 2012)
We do confirm that this Arnova 7 G2i ICS firmware can be flashed on a regular Arnova 7 G2 model. We are currently working on making a custom firmware to update the Arnova 7 G2i and the older 7 G2 model to Android 4.0 ICS with Google Play Store and root access, stay tuned ! |
Thanks to exelletor and our forum member Oream for the 7 G2i device pictures and the firmware update.
Arnova hasn't released any official ICS firmware for the 7G2.Â
The ICS firmware dump and our custom firmware will be released soon, when we are done testing.
The Arnova 7c G2 uses different hardware (Qualcomm architecture vs Rockchip on the 7 G2), so it can't use this ICS firmware, unfortunately.
You'll need to use Rockchip flasher to replace your existing firmware by the ICS custom firmware.
gen1us: As I mentioned the supplied backup.img is mainly for firmware builders and can't be flashed directly.
I'll provide a flashable stock and custom firmware later today.
globula_neagra said
i want the build.prop from this
There you go:
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=IML74K
ro.build.display.id=V2.0.3.IML74K.eng.root.20120615.040238
ro.build.version.incremental=eng.root.20120615.040238
ro.build.version.sdk=15
ro.build.version.codename=REL
ro.build.version.release=4.0.3
ro.build.date=Fri Jun 15 04:11:19 CEST 2012
ro.build.date.utc=1339726279
ro.build.type=eng
ro.build.user=root
ro.build.host=goolin-desktop
ro.build.tags=test-keys
ro.product.board=rk29sdk
ro.product.cpu.abi=armeabi-v7a
ro.product.model=AN7G2I
ro.product.brand=AN7G2I
ro.product.name=AN7G2I
ro.product.device=AN7G2I
ro.build.product=AN7G2I
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=unknown
ro.wifi.channels=
ro.board.platform=rockchip
# ro.build.product is obsolete; use ro.product.device
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=A7HC-eng 4.0.3 IML74K eng.root.20120615.040238 test-keys
ro.build.fingerprint=Android/A7HC/A7HC:4.0.3/IML74K/eng.root.20120615.040238:eng/opinions-on-teclast-p90hdst-keys
ro.build.characteristics=tablet
# end build properties
ro.yifang.weather.city=New York
ro.yifang.weather.isf=1
ro.yifang.ota.enable=0
# ADDITIONAL_BUILD_PROPERTIES
ro.com.android.dateformat=MM-dd-yyyy
ro.config.ringtone=Ring_Synth_04.ogg
ro.config.notification_sound=pixiedust.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
ro.config.facelock=enable_facelock
persist.facelock.detect_cutoff=5000
persist.facelock.recog_cutoff=5000
ro.opengles.version=131072
wifi.interface=wlan0
wifi.supplicant_scan_interval=15
persist.sys.usb.config=mtp
persist.sys.strictmode.visual=false
dalvik.vm.jniopts=warnonly
ro.sf.hwrotation=270
ro.rk.sdcard_volume=InteralStorage
ro.rk.external_volume=SDCard
ro.rk.usb_host_volume=USBDisk
ro.sf.fakerotation=true
media.demux.cfg=Matroska_Wav_Flv_Avi_Mov_Wma_Rm_Ogg_Mp3_Amr_Aac
media.decoder.cfg=MP3_AMRNB_AMRWB_AAC_DTS_WMA_AC3_RA_WAV_AVC_RV_FLV_M2V_VC1_G711_M4vH263_Vorbis_VPX
sys.hwc.compose_policy=6
persist.sys.ui.hw=true
persist.sampling_profiler=1
opengl.vivante.texture=1
webcore.adblock.enable=1
rild.libargs=-d_/dev/ttyUSB1
ril.pppchannel=/dev/ttyUSB2
rild.libpath=/system/lib/libril-rk29-dataonly.so
ril.function.dataonly=1
dalvik.vm.heapstartsize=8m
dalvik.vm.heapgrowthlimit=64m
dalvik.vm.heapsize=256m
ro.rksdk.version=RK2918_ANDROID4.0.3-SDK_V2.10_20120205
ro.product.version=1.0.0
ro.product.ota.host=www.rockchip.com:2300
ro.yifang.bluetooth=0
ro.yifang.devicename=AN7G2I
ro.yifang.autobrightness=0
ro.yifang.sync=1
ro.yifang.hdmi=0
ro.yifang.mobile=1
ro.yifang.mobile_dongle=0
ro.yifang.hotpoint=1
ro.yifang.Accessibility=1
ro.yifang.powerkeyshutdown=1
ro.yifang.datausage=1
ro.yifang.touchcalibration=1
ro.yifang.vibrate=0
ro.yifang.DRM=0
ro.yifang.usbhost=1
ro.sf.lcd_density=120
ro.yifang.default.brightness=125
ro.yifang.default.timeout=60000
ro.yifang.default.is24=1
ro.kernel.android.checkjni=1
ro.setupwizard.mode=OPTIONAL
dalvik.vm.dexopt-flags=m=y
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
ro.svn.version=5505
ro.hardware.version=1.0.0.0
ro.vendor.name=YFMID
53 Guest(s)
Devices in use: Desktop (50), Phone (3)
jacksonrid
