Arnova 7 G2 First custom firmware fully rooted by Finless
finless
Stanton, Ca
Forum Posts: 604
2012/01/06 - 03:38
OK folks the Arnova 7 G2 firmware was setup EXACLTY like the Arnova 10 G2.  Thus I made the exact same changes to the 7 G2 firmware as I did for the 10 G2.
1) Converted system.img from cramfs to ext3
2) Gave an extra 100mb space to /system so rooted apps that need it can use it.
3) Gave system memory a boost up from 225mb to 450mb.  This give more room for apps!
4) Integrated the changes Admin asked me to do to help support Arctools Market install.
Flashing the firmware requires you install drivers and use the tool I supply in this kit.  There is a README.TXT in the zip so READ IT please and follow all instructions.
THIS IS ONLY FOR THE ARNOVA 7 G2!!!
If you 7c G2 guys use this your screen will not work and you will be broken until Arnova releases a update.img for your version!!!  I also cant say if this will work on the 7b G2 but I would NOT try it since you also do not have a update.img from Arnova yet.
WARNING – USE AT YOUR OWN RISK!  Do not complain to me or the admin of this site of you brick your Arnova!  You have been warned!
FINAL WARNING - I have no way to test this firmware as I do not have a 7 G2.  However the root process was exactly liek the 10 G2. So this ROM should work.  YOU WILL BE A BETA TESTER by installing this.  Please let me know how it goes.  If it doesnt work you can flash back to stock ROM using RKbtach tool and the update.img from Arnova.  In my README I explain all that so again read it please.
OK so here is the new cooked up ROM!
http://www.helifreakswag.com/arn7g2_23_1_0_arctools.zip
Enjoy,
Bob
2012/01/06 - 09:27
I'll test it on my currently bricked 7G2, it can't get really worse 😉
Will report results here.
Edit:
Works like a charm, my 7G2 is back to life ! Smile
Nice boot picture, thanks a bunch finless.
I'll test it a little more and give feedback later.
darren
2012/01/06 - 10:19
finless, thank you for your work on this - it looks clear and simple.  I have one question.  My 7G2 does not have an external volume button to press as stated in the process for driver installation (unlike the 10G2).  Are you aware how I get my machine in to the required mode?
2012/01/06 - 10:22
The readme will need some updates for the 7G2...
Actually you need to put the power button to the right side (lock icon).
Pretty similar to the procedure here: /blog/archos-tablet/flashing-firmware-rockchip-cpu-based-devices-archos-ht-7-8-arnova-10/
Sowa
Russia, Novorossiysk
Forum Posts: 47
Thanks Received: 5
2012/01/06 - 10:30
See this http://wiki.archosfans.com/index.php?title=Unbrick_A7HT_Version2
China phone: Star A5000 => Star N8000
Tablets: Archos 7C HT - Android 2.2.1 my custom ROM => ARNOVA 8G2 8Gb capactive, s_MorkaMod JB 1.2
toxn
2012/01/06 - 11:14
Works here all right with Windows 7 64 bits.
Thanks a lot.
fenice57
Forum Posts: 49
Thanks Received: 15
2012/01/06 - 12:17
Bob, great job tks tested and works fine
Tango91
2012/01/06 - 12:34
Worked like a charm! Smile
Thanks Bob, I've been waiting months to unlock the potential inside my little Arnova.
Do you have paypal? I'd like to buy you a beer. Wink
simonkitch
2012/01/06 - 15:31
Thanks Bob, just updated my Arnova 7 G2. No issues. How do you recommend installing Google apps?
Simon
finless
Stanton, Ca
Forum Posts: 604
2012/01/06 - 15:58
I will uipdate the readme when I get home from work today.
Thanks for the tips!
Glad the ROM is working.  Kinda scary kicking out a ROM you cant test first 😉
But as I said it was exactly like the 10 G2.  Now to get the 9 G2 done 🙂
Bob
finless
Stanton, Ca
Forum Posts: 604
2012/01/06 - 17:27
Tango91, no need buddy.  If your ever in Southern California you can buy me a beer then 🙂
Simon, have a look in the 10 G2 forum.  Lots of posts about it.  Bottom line what works for me is Arctools 0.57.  Then choose Market 4.3.3 rooted install.
Bob
darren
2012/01/06 - 17:32
Worked perfectly, many thanks for your assistance! Laugh
finless
Stanton, Ca
Forum Posts: 604
2012/01/06 - 18:15
Can I ask a favor of someone please.... Since I do not have a 7 G2 to understand how to get it into recovery mode, can some update my readme with the proper instructions and send it to me?  I read the link but again since I physically do not have one I am not sure I understand the proceedures.
Bob
simonkitch
2012/01/06 - 21:15
Bob
Ok cheers Bob, that worked for me. Like to buy you a beer as well, but Southern California! Thats a long way man.
Simon
Dylbot
Forum Posts: 12
2012/01/06 - 21:52
Works like a charm. Only thing that doesn't work is Chainfire 3D, tried to install the driver and got stuck in a boot loop, had to reflash.
86 Guest(s)
Devices in use: Desktop (78), Phone (8)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
